Replaced fuel filter, gas coming out of fuel line??? 93 del sol si
I replaced my fuel filter and tightened both gas lines. but when i start the car, gas comes pouring out of the gas line going into the filter. did i do something wrong??
the car is a 93 del sol si.
yeah, i used the washers that came with the new filter. i dont have a torque wrench so i just tightened the bolt down until it was snug. should i just go to kragens and get new crush washers?
You really need to torque it to spec - if you don't have a torque wrench, some autoparts stores will loan you one.
there are two washers that come with the new filter. one goes on top of the banjo, and the other goes below the banjo, right?
Correct.
Like the other guys said it's important that you torque that bolt.
A buddy of mine tried to do it on his own and had the same problem, but when I torqued it for him it was fine. Good luck.
Archxor
Nov 7, 2006 04:36 PM
