Rear washer trick for egs..
Old Nov 27, 2001 | 09:03 AM
Night Kid's Avatar
New User
Default Rear washer trick for egs..
anyone know how to correct the rear camber with washers? i mean, where does the washers go with the longer bolts? thanks. pictures would be very nice..
Old Nov 27, 2001 | 09:09 AM
gsrvx's Avatar
New User
Default Re: Rear washer trick for egs.. (civicnightracer)
Hey bro....try this link: http://www.jdmfan.com/technical/suspension/rear_camber/
Old Nov 27, 2001 | 09:10 AM
stkd16z6's Avatar
if you use more than two washers, you should use longer bolts. and try to use stainless washers. last time i used galvanized and they rusted
Old Nov 27, 2001 | 06:08 PM
Night Kid's Avatar
New User
Default Re: Rear washer trick for egs.. (stkd16z6)
thank you very much!!
Old Nov 27, 2001 | 08:30 PM
Cyrio's Avatar
hahah, i thought you meant, rear windshield wiper, when you said washer. my bad.
Old Nov 27, 2001 | 08:59 PM
Night Kid's Avatar
New User
Default Re: Rear washer trick for egs.. (Cyrio)
lol
NE ways, i read the article and it said every washer adds about +.5 degree. it also says i should add one washer per inch lowered. my car is dropped 2.25 inches in the back (no flames please!!) so would i need 2 washers or 3 washers? thanks..
[Modified by civicnightracer, 10:00 PM 11/27/2001]
Old Nov 27, 2001 | 09:22 PM
KEVlN's Avatar
New User
I would also like to know how many washers and the correct size bolt for this much of a drop. I have the same amount of drop as "civicnightracer".
Old Nov 27, 2001 | 10:04 PM
gsrvx's Avatar
New User
Default Re: Rear washer trick for egs.. (Civic95)
I think how many washers you add should depend on how bad ur camber is....not how low. Take it to an alignment shop and see how many degrees ur camber is off first.
nk2k2
17
Sep 4, 2009 01:23 AM
lil k
May 19, 2003 12:22 AM
p0pe
May 22, 2002 06:30 AM
albert butterbikini
Jan 27, 2002 02:00 PM
