NEED HELP W/ JDM DOOR PANELS FOR CRX
Old Jul 28, 2004 | 10:41 AM
spec:jdm's Avatar
Default NEED HELP W/ JDM DOOR PANELS FOR CRX
I NEED HELP, IM PLANNING ON BUYING JDM DOOR PANELS FOR MY EF8. IM NOT SURE WHAT TO DO WITH THE SEAT BELT SINCE THE JDM PANELS DONT HAVE THE PLACE FOR THE SEAT BELTS AND THE USDM DO. DOES ANYONE HAVE EXPERIENCE WITH THIS BEFORE? THANKS ALOT.
Old Jul 28, 2004 | 11:22 AM
Eggman's Avatar
Default Re: NEED HELP W/ JDM DOOR PANELS FOR CRX (jockable247)
well, the 88 usdm crxs have seat belts on the b-pillar. you can weld the bolt to the b-pillar like 88s or get a aftermarket harness.
keep in mind the jdm door panels have a longer cutout for the drivers door handle (power window switches).
Old Jul 28, 2004 | 12:10 PM
kur0ryu's Avatar
Default Re: NEED HELP W/ JDM DOOR PANELS FOR CRX (Eggman)
Yup, be aware also if you're welding anchor nuts into the b-pillar, the driver side also needs a floor anchor. The passenger side already has the floor anchor, but for some stupid reason honda half-assed it. So total you should need 3 anchors welded in.
Old Jul 28, 2004 | 12:18 PM
rexerk's Avatar
I was curious about putting the power windows in my 89 CRX SI, could i simply cut out the slot by the handle to fit the JDM handle with switches in it? Or do I have to have the JDM panel to fit the motors etc.?
Old Jul 28, 2004 | 12:35 PM
CRX T-Si's Avatar
Default Re: NEED HELP W/ JDM DOOR PANELS FOR CRX (ullerw)
I have the PW in my 88 Si.
Love it alot except I fried the one touch up and one touch down for the pass. side.
Have pics on my site.
Old Jul 28, 2004 | 03:42 PM
kur0ryu's Avatar
JDM power windows will put the driver side control on the right door, unless you flip the switch upside-down and put it on the driver side door. you'll have to re-wire though.
Old Jul 28, 2004 | 03:46 PM
CRX T-Si's Avatar
Default Re: NEED HELP W/ JDM DOOR PANELS FOR CRX (kur0ryu)
It dose not work that way buddy.
I tried to flip it and it does not fit right.
to make things less complicated you can install an aftermarket onto the center console somewhere to control the windows.
Old Jul 28, 2004 | 09:25 PM
spec:jdm's Avatar
Default Re: NEED HELP W/ JDM DOOR PANELS FOR CRX (CRX T-Si)
what if i get the jdm power window kit (switches, longer door handles/lock, and window scissor thingy) use my usdm stock door panels and just put a plastic cover on the hole where the window handle use to be, would the jdm window scissor fit in my door without modifications?
Old Jul 29, 2004 | 06:09 AM
kur0ryu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">It dose not work that way buddy.
you have to modify the door handle bracket to flip it but yes it can be done. (I've done it).
Old Jul 29, 2004 | 06:35 AM
CRX T-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jockable247 &raquo;</TD></TR><TR><TD CLASS="quote">what if i get the jdm power window kit (switches, longer door handles/lock, and window scissor thingy) use my usdm stock door panels and just put a plastic cover on the hole where the window handle use to be, would the jdm window scissor fit in my door without modifications?</TD></TR></TABLE>
Yes, it will fit.
If you look at your USDM door handles on the back, you will see the outline for the powerwindow switch. It's about an 1 1/2" to 2" longer towards the front of the handle. That is all, in fact I am going to switch back to my USDM door panels cause it says CRX on it. The JDM ones I got is kind of worn out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kur0ryu &raquo;</TD></TR><TR><TD CLASS="quote">
you have to modify the door handle bracket to flip it but yes it can be done. (I've done it).</TD></TR></TABLE>
I will see what must be modified to get this working. Since you did it can you post some pics of the finished product???
Old Jul 29, 2004 | 07:57 AM
kur0ryu's Avatar
I will see what must be modified to get this working. Since you did it can you post some pics of the finished product???</TD></TR></TABLE>
I can't take pics right away, but I can say the inner door handle bracket just needs to be flipped, and if I remember correctly you just have to re-drill the screw hole to match.
hmonkey86
Mar 4, 2012 06:07 AM
89 Crex
13
Nov 15, 2010 04:03 AM
cor4ey
Jun 16, 2009 01:33 PM
Turbo-JC
Audio / Security / Video
Jul 20, 2003 07:50 AM
