Allright this is cracked in my car could this affect my cars vibartion?
might want to replace it...
its a good mount to have strong..
imo...
but yeah it is probally causing your vibrations.... cause your engine has so much play.... so... get a new one....
imo...
Ya, the same thing happened to me, well i lost that one mount for my driver side while doing a swap, ive been driving without it for a while, to tx a few times (from FL) and now i took it up to KY (thats where im at now) it does vibrate a lot, i need to get mine check too
That is your transmission torque mount, those rubber inserts are weak and they do not last long, especially after a swap. Those mounts are designed to hold the block steady during load and it will cause the car to vibrate if it's deteriorated.
do it the smart way
just get es mount inserts and it will be much better than just replacing it
and it will help u with wheel hop
Guest
Posts: n/a
I have swapped in my engine about 5 time in one year. One was for a shortblock exchange other was tranny exchange twice and I had to take it off for the clutch installation
11seclude
Welding / Fabrication
May 4, 2005 02:42 PM
