endyn / je piston question...
Old Nov 27, 2001 | 08:21 AM
immortal's Avatar
Banned
Default endyn / je piston question...
just wondering.....if you look on larrys site you can see the picture of the wiseco piston when he first gets it, and then after he sands it down. i was just wondering if you could apply this same logic to sanding down the sharp edges on the je pistons....would it work just as well? negative effects? hmm just a thought.
Old Nov 27, 2001 | 08:26 AM
SMSP's Avatar
Default Re: endyn / je piston question... (immortal)
JE, Toda or any piston that has sharp edges. Just be conservative. Check out HXguy's post.
Old Nov 27, 2001 | 08:42 AM
immortal's Avatar
Banned
Default Re: endyn / je piston question... (SMSP)
yeah....use like 600 grit? something really fine... ?
just slightly.
Old Nov 29, 2001 | 11:07 AM
Weslay's Avatar
sharp angles and edges get extra hot, smoothing the edges a little battles against detonation
luckypon7
Dec 31, 2003 12:40 PM
Red_Si
Jun 12, 2002 08:13 PM
immortal
Nov 27, 2001 01:19 PM
