WIll a 205/60/15 fit our teg? Currently I'm running 205/55/15 on the back.
Old Jul 28, 2004 | 08:13 AM
integraboi1010's Avatar
Default WIll a 205/60/15 fit our teg? Currently I'm running 205/55/15 on the back.
But the front have more gap....was wondering about putting a 60 series on the front to reduce the gap. Is there a big differences visually if I put a 55 in the back and 60's in the front?
Old Jul 28, 2004 | 08:25 AM
oldskool teggy's Avatar
Default Re: WIll a 205/60/15 fit our teg? Currently I'm running 205/55/15 on the back. (integraboi1010)
it depends on the tire.... some tires will have bigger looking sidewalls no matter what profile. i think it'll look a bit bulbous, but no ones gonan notice it when youre rolling.. and 55 series tires on a gs-r come stock.. so i think any 55 series tire will somewhat look the same on gs-r rims.
Old Jul 28, 2004 | 09:31 AM
purplegsr's Avatar
Default Re: WIll a 205/60/15 fit our teg? Currently I'm running 205/55/15 on the back. (Oldskool teggy)
I really wouldn't go that big. The optimal sizes are 195/55/15 (stock size) and a lot of people run 205/50/15 (increase in width makes up for decrease in side wall % - so it ends up with a similar sidewall height to stock). 60% of 205 would put you at 123mm, while 55% of 195 is 107.25.
The tires you are considering would make your sidewall about 8mm thicker all around, which seems like a lot to me. If you are lowered, you run the risk of rubbing. Of course, if you have a more boxy tread, the difference may not be noticeable appearance wise, but I think that extra sidewall would make your car sit higher and look somewhat funny, and probably not handle very well.
Do you have 205/55 in the back? or 195/55?
Old Jul 28, 2004 | 10:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
205/55 tires look like balloons on stock wheels, and 205/60 would look even worse (dang my mom's Avalon has that size tires)
Stick w/ 195/55 or 205/50 all around.
princefredo
Jun 30, 2006 06:11 PM
civic702
Feb 21, 2005 01:39 PM
v0lcom27
10
Feb 15, 2005 09:50 AM
kinvid22
Mar 30, 2004 12:06 AM
TRAY
Oct 13, 2002 06:04 PM
