Grey cast iron sleeves and forged pistons?
Old Jul 28, 2004 | 07:05 AM
pentaq's Avatar
Default Grey cast iron sleeves and forged pistons?
Will it work? Would it be good for boost?
Mahle is making sleeves made of that material...
Any input please...
Old Jul 28, 2004 | 11:00 AM
prelittlelude's Avatar
Default Re: Grey cast iron sleeves and forged pistons? (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">Will it work? Would it be good for boost?
Any input please...</TD></TR></TABLE>
as long as they are TRUELY cast iron, then forged will be good
the question of good for boost depends on how thick the replacement sleeve is, if its a 1mm drop in sleeve or a huge thick slevee like darton or GE use
Old Jul 28, 2004 | 11:20 AM
fastludeh22's Avatar
Default Re: Grey cast iron sleeves and forged pistons? (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">
the question of good for boost depends on how thick the replacement sleeve is, if its a 1mm drop in sleeve or a huge thick slevee like darton or GE use</TD></TR></TABLE>
I DONT CARE WHAT THEY TELL YOU, WHAT SIZE THEY ARE, OR WHO THE HELL IS ENDORSING THEM....DONT USE THEM FOR BOOST!!!!!!!!!!!!!!!!
nothing against that company but i learned the sleeve lesson the hard way. if its for n/a, then get the cheapest sleeve you can find. if for boost, or any kind of real n2o use go with top name brands.
Old Jul 28, 2004 | 01:46 PM
pentaq's Avatar
Default Re: Grey cast iron sleeves and forged pistons? (fastludeh22)
Didn't you use the sleeves meant for turbo diesel engine? I think they must be strong as those modern diesels have some serious boost (close to 2 bars)
Old Jul 28, 2004 | 06:16 PM
PirateMcFred's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">Didn't you use the sleeves meant for turbo diesel engine? I think they must be strong as those modern diesels have some serious boost (close to 2 bars)</TD></TR></TABLE>
Don't forget that most diesels have like 15-17:1 compression too. Talk about cylinder pressure!
Pirate
Old Jul 29, 2004 | 02:05 AM
pentaq's Avatar
Default Re: Grey cast iron sleeves and forged pistons? (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">
Pirate</TD></TR></TABLE>
The pressure must be incredible, so that's why I think they are enough durable to carry the moderate boost in H22 (let's say ca. 1 bar).
There was a guy here who got his sleeves made from Mercedes turbo diesel and they seem to be strong enough though.
Another question: how thick are those brand sleeves (Darton)?
Old Jul 29, 2004 | 07:04 AM
thats what i thought, and was told.
The pressure must be incredible....
Another question: how thick are those brand sleeves (Darton)?</TD></TR></TABLE>
again what i was thinking.
and what happens when your wrong:
https://honda-tech.com/zerothread?id=870704
and a link to benson's, which uses darton sleeves...
https://honda-tech.com/zerothread?id=565375
Old Jul 29, 2004 | 07:24 AM
pentaq's Avatar
yes, I have seen those pix before. But you know there were some other factors: your bore 90mm and rather high boost (19psi) which could help to damage that engne.
I would like to stay at 87mm and moderate boost. So I ask again: how thick should be the sleeves to hold boost on 15 psi level? 3mm or more?
I don't even think about sending my engine to the States to get sleeving done as it would cost me almost another two engines
Old Jul 29, 2004 | 06:40 PM
yes you are right, but i believe that these other sleeves would have held.
i don't think its all about thickness. it has to do with exact material mix, and processing. you can buy sleeves from darton and have them installed locally.
all i can say about those take a chance if you want. but as much as you say you wont go above 15 psi...you will in a month, trust me. especially if all else is built and your not sure about the sleeves, you will push them.
my new machinist said it to me like this, "if you cant afford to do it right, can you afford to do it twice?"
Old Jul 30, 2004 | 12:46 AM
pentaq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">my new machinist said it to me like this, "if you cant afford to do it right, can you afford to do it twice?"</TD></TR></TABLE>
Very true. I can't afford to fix a serious damage in my engine, so I'll save for Dartons then and will have them installed locally.
This is the consensus Thanks.
{edit}
I have just found out Darton is a part of Portugal company, so it could be easier for me to get those sleeves.
Mechman456
Honda Civic (2006 - 2015)
Nov 6, 2007 11:25 AM
SpoolnByYou
Dec 19, 2005 02:28 PM
VRD^don
Mar 4, 2005 01:32 PM
k-cerez
15
Nov 25, 2004 08:59 PM
darkdayz
Nov 11, 2004 04:17 AM
