Inlet manifold removal
again...dont think there is a 92 vtec...i could be wrong but ive never heard of one before.
I stand corrected....sorry was not thinkin bout jdm
Modified by Slipknt777 at 6:14 PM 7/31/2004
The biggest pain are the bolts underneath the manifold. Good luck getting them off or on once you're done. Dont forget the mounting bracket on the bottom side either. other than that... Remove fuel, remove Vacuum, (ALL) Intake tube, Coolant lines, and all connectors. (injector connectors, Air temp, IAC, EGR, Map, TPS) Map sensor might be on the firewall. It depends on what swap you did.
Don't seperate the upper and lower with the butterfly's. There's no need.
Have all new gaskets ready.
there is a write up with pics on http://www.preludeonline.com. you have to sign up
(costs 6 bucks) to access it though. The write up is great and the site itself is worth the 6.00 regristration fee.
Thanks guys. Thought it would be a PITA to remove it with the engine in. I'm in the middle of installing DP nitrous, and thought I may as well install my Hondata intake manifold gasket at the same time. Perhaps I'll do that at a later date though!
vtec_lude (sorry dude, I can't remember your proper name!) - are you going to Ten Of the Best 3 on Sunday? Will be an AWESOME day!!
Adam it's cool.. the name's Alan... Nah mate aint going to ten of the best!!!! I've got work and the car is playing up!! let me know what happens though.. you getting your nitrous in before it?? you running??
boomersz
Jan 25, 2007 09:34 PM
JBk24crx
30
Nov 12, 2003 04:45 PM
