Won't Go but often starts
Ok last nite my friend wanted me to change his thermostat because his car is getting hott, so i did. Before i took it to my house the car started fine with no problems but needs gas. i finally get to my house and i don't see it running hott so i start taking off the strut, short ram intake and the parts to get to the thermostat. I move a couple of wires here and there and change the thermostat with no problem. Put everthing back together with no problem and turn the car on so i can put coolant in it. The car was low on gas and i thought that why it did not start, i put gas in starts right up. Then all of sudden it turns off, well i turn it on again and it running fine i drive it for 15 min the it shut off. I push it back to my house cuz it was not that far but i try to turn it on again and it start iding funning like 2 to 1 for like 30 seconds. I check all the wiring everything back in place when i saw what is wrong the car is it a 91 teg. the car will start and it will shut off i check the rotor it was fine but i happen to move one of the fuel wires and i heard air coming out, could i have move something to have a vaccum leak please help me!
Problem: car starts, will start right up idles funny, not like normal(1,1/2)
car shut off when you are driving it, it also hestates doesn't back fire but
jerks
Please tell me what this could be need to know asap
Modified by 89CivicHatch at 6:10 AM 7/28/2004
jerks
Acrappyhatch
Mar 5, 2007 08:24 PM
