painted dash. can you get it off?
Old Jul 27, 2004 | 08:25 PM
Origin's Avatar
Default painted dash. can you get it off?
theres a guy im buying a dash from and some of the pieces are painted red. can you use aircraft paint to remove this paint and restore it to its original condition? or is it not worth it and i just need to look a little more?
Old Jul 27, 2004 | 08:34 PM
crexer's Avatar
Default Re: painted dash. can you get it off? (Origin)
get some goof off remover and just dilute it with water so it wont discolor your dash...make sure they guy didnt sand the dash or something before he painted it cause that wouldnt look to hott
Old Jul 27, 2004 | 08:41 PM
Steemo's Avatar
Default Re: painted dash. can you get it off? (crexer)
the aircraft paint removal stuff is too strong. i think it will eat through the vinyl or whatever material the dash is made of. the guy i bought my crx from painted the dash blue and you can almost just scrub the stuff off with hot water and soap but its a tough scrub. i would just keep looking around and find something thats untainted. that would be your best bet.
Old Jul 27, 2004 | 09:06 PM
Origin's Avatar
Default Re: painted dash. can you get it off? (Steemo)
well its mostly around the center of the dash where the vents are, going down where the radio would be mounted and down to where the shift linkage comes through, which i believe is a plastic. the dash itself is the original color. that should be removable right?
Old Jul 27, 2004 | 09:17 PM
shaddr3's Avatar
get some rubbing alcohol, should do the trick :-/
Old Jul 27, 2004 | 09:18 PM
ThatRicerDaniel's Avatar
3m now makes a type of goo remover Waaaay better than goo gone and its in a spray can. 3m is always quality.
Old Jul 27, 2004 | 09:24 PM
Origin's Avatar
Default Re: painted dash. can you get it off? (ThatRicerDaniel)
cool thanks guys.
Old Jul 27, 2004 | 10:41 PM
hondatahatch's Avatar
Old Jul 27, 2004 | 11:09 PM
Dwight Schrute's Avatar
Default Re: painted dash. can you get it off? (hondatahatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatahatch &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
what exactly was the point of your post?
Old Jul 28, 2004 | 06:34 AM
VashTheStampede's Avatar
No tears. Only dreams, now.
His post is about as worthless as yours, and the one that I'm making now.
Old Jul 28, 2004 | 06:44 AM
slowpokesi's Avatar
Default Re: (VashTheStampede)
Spray it on, and rinse it off, if you only leave it on there for a minute or 2 it wont damage it.
90ZCREX
Aug 3, 2011 07:11 PM
hondaj05
44
Apr 18, 2006 07:39 PM
4DRmafia
Apr 3, 2005 01:57 AM
toohotcivic
14
Dec 22, 2004 10:20 PM
