CRANE VS. MSD IGNITION
Old Jul 27, 2004 | 07:22 PM
MenaceL.A.671's Avatar
Default CRANE VS. MSD IGNITION
whats a good ignition for lsvtec?? i have a 6al, but not sure if i should run it!!? but im in the process of buying a new one...! so yea man i need help on whats best to get... MSD DIS-2 or CRANE HI-6 CD Ignition??? or what yall recommend is good??? thanks!!!
Old Jul 28, 2004 | 04:06 AM
Default Re: CRANE VS. MSD IGNITION (m2slsvtec)
HELP!!!
Old Jul 28, 2004 | 04:17 AM
therealpoorboy's Avatar
if your a street guy and wont be seeing alot of track time then the crane is better. if your gonna be racing alot MSD is better.
crane dosnt use pills just a simple dial.
Old Jul 29, 2004 | 02:04 PM
smokey2.0's Avatar
Default Re: CRANE VS. MSD IGNITION (therealpoorboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therealpoorboy &raquo;</TD></TR><TR><TD CLASS="quote">if your a street guy and wont be seeing alot of track time then the crane is better. if your gonna be racing alot MSD is better.
crane dosnt use pills just a simple dial. </TD></TR></TABLE>
i don't see why a dial, would not be ideal if you drag race. i would rather turn the dial, then have to find the a rpm pill! but thst's my opinion
Old Jul 29, 2004 | 02:26 PM
Default Re: CRANE VS. MSD IGNITION (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
i don't see why a dial, would not be ideal if you drag race. i would rather turn the dial, then have to find the a rpm pill! but thst's my opinion </TD></TR></TABLE>
because a crane 2-3 step costs about $250. and it dosnt work with the FAST system that i use. and what happens if the dial goes bad? you have to fork out another 250. if the msd goes bad 9 outa 10 times you just replace the cheap pills.
Old Jul 29, 2004 | 03:27 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therealpoorboy &raquo;</TD></TR><TR><TD CLASS="quote">because a crane 2-3 step costs about $250. and it dosnt work with the FAST system that i use. and what happens if the dial goes bad? you have to fork out another 250. if the msd goes bad 9 outa 10 times you just replace the cheap pills.
the price alone would keep people from buying it, now that i think of it i should be reseiving a msd 2step that i bought here in H-T it was pretty cheap, so i picked it up. now i have to see what would be the easiest way, to set it up on my 88 crx!
Old Jul 29, 2004 | 06:19 PM
non-VTEC's Avatar
i like the crane hi-6 over the MSD ignitions with the "pills"
the MSD digital 6 is a nice unit. probably more comparable to the crane hi-6.
Teamdiesel
32
Dec 8, 2007 04:45 AM
StreetRac3r
Jun 2, 2007 08:31 PM
Conernr1
12
Dec 3, 2004 01:16 AM
Captn. Save A Hoe
Nov 15, 2003 12:58 AM
1.8T_EG
May 14, 2003 09:45 AM
