No High Cam
Old Nov 27, 2001 | 04:50 AM
urbanlegend21's Avatar
New User
Default No High Cam
My check engine light came on this morning, but I haven't had a chance to check it yet.
I know one thing: i have lost the high cam you can feel the power die at about 4000 rpm
i am thinking I might have low oil because it has done this before, just not this bad. i put a little oil in it at the gas station and may have over filled it, is it possible the car has to much oil and is throwing a VTEC solenoid code?
_______
Old Nov 27, 2001 | 04:57 AM
sohc_boy's Avatar
Default Re: No High Cam (urbanlegend21)
if u don't change your oil regularly u might get some sludge which can clog the vtec solenoid and prevent it from functioning. one of my friends had this happen to his lude he didn't change the oilf for like 9000 miles and never chk'd it either and than his vtec wouldn't engage. he changed the oil (after an engine flush) and his vtec was fine. although this is a simple fix its worth a shot.
Old Nov 27, 2001 | 05:08 AM
New User
Default Re: No High Cam (sohc_boy)
i change every 3,000 on schedule, i have recently taken my solenoid off and cleaned it after experiencing a similar problem before
Old Nov 27, 2001 | 06:19 AM
MrBite's Avatar
I'm pretty sure whenever your CEL comes on, VTEC is disabled by the ECU. Sort of as a precaution I guess.
hotdoggies
Apr 11, 2005 04:25 AM
NSX Bob
Apr 13, 2002 04:10 PM
Terry_shum
16
Dec 26, 2001 09:16 AM
BoM
Oct 2, 2001 05:59 PM
MontrealR
Sep 15, 2001 07:51 PM
