camber kits
Old Jul 27, 2004 | 05:46 PM
xdavidx's Avatar
Default camber kits
what would you guys suggest getting if you are running h&r racing springs with stock shocks on a 96 gsr. i am also looking for koni yellow shocks if anybody are selling them.
Old Jul 27, 2004 | 05:49 PM
typeR#0427's Avatar
Default Re: camber kits (xdavidx)
I have an SPC camber kit on the front of my teg. It only took me about an hour to install it, and it gave me plenty of adjustability for the camber.
I the rear you might not need one, or you can just buy some longer bolts and some washers to shim out the back, I have not done this though, I really don't know how well it works.
Old Jul 27, 2004 | 06:32 PM
gsrboi80's Avatar
Default Re: camber kits (hamB18C5)
I have Tein SS dampers. Skunk2 front and ingalls rear camber kits adjusts fine. You should definatly invest in performance shocks youll ware them stockers out fairly quick.
Old Jul 27, 2004 | 07:07 PM
lanojp1's Avatar
SPC are quality products, had them on my civic and plan on using them on my GSR...
Old Jul 27, 2004 | 07:09 PM
Elemental's Avatar
dont install the race springs yet. wait till you get the other stuff and do it all together. ingalls squeaks. spc.
Old Jul 28, 2004 | 12:00 AM
typeR#0427's Avatar
definatly don't forget about the shocks
Old Jul 28, 2004 | 12:05 AM
albsgsr's Avatar
depending on how low the springs drop ur car, you may or may not need a kit. Check with a reputable alignment shop to see if you need one or not. I'm runnin an ingalls kit in front and the washer trick in back and I have plenty of adjustability on my sportlines.
Old Jul 28, 2004 | 12:22 AM
TurboTony's Avatar
Skunk II Camber Kit is pretty good from what I have heard.
Old Jul 28, 2004 | 08:47 AM
oldskool teggy's Avatar
Default Re: camber kits (TurboTony)
good value, famous racer and engine builder
http://www.omnipowerusa.com they have a kit for cheap that works on front and rear.
Old Jul 28, 2004 | 11:11 AM
xdavidx's Avatar
Default Re: camber kits (Oldskool teggy)
wow thx for all of the input everybody. so does the SPC, Skunk 2, or the omni camber kits have any problems like rubbing or bottoming out or anything?
Old Jul 28, 2004 | 12:16 PM
they are all differt style kits.. the skunk2 and omni kits use a differnt control arm.. its a whole new piece.. the spc one, if its like the sprint, or ingalls kits does not.. it pushes the mounting points of the stock control arm out.. and therefore if you try to add too much positive camber.. your arms will hit the fender well. i corrected about 2.5-2.8 degrees on mine and i have no problems.. i have an ingalls style kit. also it depends on how low your car is..
i'd go with the newer whole control arm design.
goodluck!
Old Jul 29, 2004 | 04:49 PM
xdavidx's Avatar
i dont know how much camber i have to correct, but i know that i will be running with h&r racing springs with the koni yellow shocks. ill look into the skunk2 and omni a little more and ill see what ill end up getting. thx oldskool teggy
Old Jul 29, 2004 | 06:16 PM
skunk2eg's Avatar
ingalls is really good for the price..... be sure to set it to a little bit of negative camber
Old Aug 21, 2004 | 10:13 PM
xdavidx's Avatar
Default Re: camber kits (skunk2eg)
bringing it back because i am still thinking about which to get. i think i narrowed it down to either skunk 2 or the omni power ones. between those two choices which would you guys suggest considering price and anything else you can think of. thx for any input!
Old Aug 21, 2004 | 10:19 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I am probably going to get OmniPower front and rear upper arms so that I can dial in my camber to about -1.8 in front and somewhere around -1.25 in back.
Whatever you do, don't adjust it to straight up 0 camber, as that will negatively affect handling.
Old Aug 21, 2004 | 11:01 PM
Jeff_B's Avatar
Default Re: camber kits (PatrickGSR94)
Anyone use the Sprint rear camber bolts? They are $15 for a pair and apparently enable you +/- 2.00 degrees of adjustment.
-Jeff
Old Aug 21, 2004 | 11:21 PM
xdavidx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I am probably going to get OmniPower front and rear upper arms so that I can dial in my camber to about -1.8 in front and somewhere around -1.25 in back.
Whatever you do, don't adjust it to straight up 0 camber, as that will negatively affect handling.</TD></TR></TABLE>
good information and thx for the input
Old Aug 21, 2004 | 11:45 PM
xdavidx's Avatar
just a question sorry if it sounds stupid. so when you buy either skunk2 or omnipower camber kits they have upper control arms for both front and back right? the reason i ask because i search on ebay and stuff and i always see that they say they are selling front and rear camber kits and show the two front upper arms and show something like washers and bolts for the rears...? is it always like that or are there upper arms for the rears also? thx in advance.
Old Aug 22, 2004 | 05:08 AM
Xsi's Avatar
Xsi
I like my Ingalls, no signs of the squeaking people complain of since I greased it properly.
Old Aug 22, 2004 | 05:54 AM
njandrewg's Avatar
skunk2 is only a front kit...cuz thast where 90% of ur camber wear happens....for rears just get some washers and mount them with the bolts. Depends on springs...but for neuspeed race springs its 2 washers on each bolt
Old Aug 23, 2004 | 01:25 AM
xdavidx's Avatar
Default Re: camber kits (njandrewg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 is only a front kit...cuz thast where 90% of ur camber wear happens....for rears just get some washers and mount them with the bolts. Depends on springs...but for neuspeed race springs its 2 washers on each bolt</TD></TR></TABLE>
thx alot that is exactly what i was looking for. i got h&r race springs and is expecting koni yellows sooner or later, so i think i might need some camber adjustment in the rear. thx again
edit: anybody with h&r racing springs and koni yellows using the washers and bolt for the rear? if so how many washers did you use?
Modified by xdavidx at 10:41 AM 8/23/2004
Old Aug 23, 2004 | 02:11 AM
alfaaay's Avatar
Are you getting a camber kit for adjustability? From what I've seen and experienced, most cars don't need a camber kit to take care of uneven tire wear. All they need is a good alignment that'll get the toe angles straightened out. A camber kit would be a good option if you wanted exact settings.
Old Aug 23, 2004 | 02:21 AM
xdavidx's Avatar
Default Re: camber kits (alfaaay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfaaay &raquo;</TD></TR><TR><TD CLASS="quote">Are you getting a camber kit for adjustability? From what I've seen and experienced, most cars don't need a camber kit to take care of uneven tire wear. All they need is a good alignment that'll get the toe angles straightened out. A camber kit would be a good option if you wanted exact settings.</TD></TR></TABLE>
yea i went for an allignment, but the shop said that my car was to low and that they can't adjust it. i kinda expected it, but yea so thats why i am looking for a camber kit.
Old Aug 23, 2004 | 04:59 AM
Community Builder
You know I've been saying that for a long time, but my camber is sitting around -2.8 right now, and I'd like to dial it in closer to something like -1.8 to -2.0 or so.
As for the rear, I want precision adjustability. None of this washer crap for me, I'm getting the OmniPower rear upper arms which have a turnbuckle-style adjustment (similar to the front tie rods) for precise adjustment. I also plan on getting rear toe control links w/ the same type of adjustment, to get more precise toe settings, vs. having to just use a prybar on the trailing arms.
Old Aug 23, 2004 | 05:01 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xdavidx &raquo;</TD></TR><TR><TD CLASS="quote">
yea i went for an allignment, but the shop said that my car was to low and that they can't adjust it. i kinda expected it, but yea so thats why i am looking for a camber kit.</TD></TR></TABLE>
well if the car is too low to get on the rack, a camber kit isn't going to help.
If they said they can't adjust the toe even w/ the car on the rack, because it's too low, well then that's BS. My car is lowered at least 3" and my friend aligns it just fine.
