gas ported high compression pistons..?
Old Jul 27, 2004 | 05:30 PM
sohcfreak's Avatar
Default gas ported high compression pistons..?
Can anybody tell me what advantage you can get out of gas port high compression piston..? and do they make them for d16..? also where can i get them..i need 78mm size
Old Jul 27, 2004 | 05:40 PM
machine4321's Avatar
basiclly they allow the extreme pressure from high compression pistons to vent through the holes and on to the top piston ring pushing them against the cylinder walss allowing a better seal ...instead of some of the compression leaking by the rings
Old Jul 27, 2004 | 05:47 PM
tegasaurus's Avatar
Default Re: (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">basiclly they allow the extreme pressure from high compression pistons to vent through the holes and on to the top piston ring pushing them against the cylinder walss allowing a better seal ...instead of some of the compression leaking by the rings </TD></TR></TABLE>
couldn't you replicate this same affect with a higher duration cam?
Old Jul 27, 2004 | 05:53 PM
sohcfreak's Avatar
nice info....thanks
Old Jul 27, 2004 | 05:57 PM
Fkned's Avatar
Default Re: (tegasaurus)
no cams have nothing to do w/it.all they do is force the rings against the cyl walls harder to seal better.But it causes cyl wear to accelerate.
Old Jul 27, 2004 | 06:08 PM
non-VTEC's Avatar
Default Re: (fkned)
i dont know if it would cause the cylinders to wear faster but it will wear the compression ring slightly faster.
so i have heard.
you should try asking Jeff and importbuilders.com if he can get you some custom gas ported pistons for the D16. he sells them for the B series engine.
90efhatch
Sep 8, 2010 07:47 AM
95 vtec
11
Aug 1, 2007 11:11 AM
ExospeedAMcrx
Aug 19, 2004 08:00 AM
