what makes a piston high or low compression
what makes a piston high or low compression? I mknow the differents but what is it about the piston that makes it High or low
Thanks and sorry if this is a dumb ?
Re: what makes a piston high or low compression (95 vtec)
in simple terms,
low compression pistons have a "dished" top.
high compression pistons are "domed" on top
the dome of the piston is what makes it high or low compression.
the higher the dome the higher the compression is, because it closes the room, for that of the air/fuel to burn. and vice versa
Re: what makes a piston high or low compression (jpnucrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpnucrx »</TD></TR><TR><TD CLASS="quote">the dome of the piston is what makes it high or low compression.
the higher the dome the higher the compression is, because it closes the room, for that of the air/fuel to burn. and vice versa</TD></TR></TABLE>
thanks man that helps alot
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 vtec »</TD></TR><TR><TD CLASS="quote">do u know where I can find pics of what dished top and domedtop look like </TD></TR></TABLE>Google Image search High Compression Piston and then Search Low Compression Piston.
just wondering how the make the diffent types. I like to learn as much as I can because cars are becoming my life. I love my Honda.
D Tranny Guru
dome doesn't mean it's high compression.
I can take a motor, remove the dished pistons and installed dome one and DROP the compression........due to the pin location and over all design.
Re: (Mista Bone)
Great.....confuse him/her whoever even more... Search like said. Pin location does make a difference but High compression and low compression is related to the volume within the combustion chamber. Dome pistions in most cases reduces that space therefore increasing compression ratio and the reverse for dish pistons. But continue to search and research.
