wiring help
Old Jul 27, 2004 | 04:31 PM
1fst4's Avatar
Default wiring help
So sunday i installed my nitrous kit and while i was doing this i decided to pull up the carpet to plug up some leaks
So i get everything done go to start the car it takes a min to crank and then it sounds like its misfiring so yesterday i looked all through it for if i pulled out a wire or something but nothing
So today i buy a volt tester and as im checking wires i don't get any power from
the c1 or c2 plugs
on the distributor i don't get any power from the blue wire that you tap for the tac if you have one
car runs and drives but spudders all the time its also throwing a code 16(injectors)
But i checked all the injectors and they are all getting power so i what to no why am i not getting power to the c1/c2 plugs?
Old Jul 27, 2004 | 05:01 PM
1fst4's Avatar
so i guess my question is Shouldent the c1,c2 wires have power coming from them with the car on
and since they dont what can i do to fix it
It wont throw the code when you just turn the key but as soon as you start it the code comes on
Old Jul 27, 2004 | 05:14 PM
bossman032's Avatar
Default Re: (1fst4)
code 16 will cause ur car to backfire etc.
also will the cyp sensors. check the injectors might be dead.
umm cyp sensor plug them back in or test it inside the car..
Old Jul 27, 2004 | 06:38 PM
1fst4's Avatar
whats the cyp sensor?
Does it have anything to do with the c1/c2 wires going to the dizzy because im not getting any power from them and cant figure out why im not getting power from them
Old Jul 27, 2004 | 06:51 PM
Dyn0speed's Avatar
Default Re: (1fst4)
code 16
check the injector resistor box for resistant if i were u
Old Jul 28, 2004 | 02:28 PM
1fst4's Avatar
Default Re: (Dyn0speed)
resistor box has power coming from all the wires
The only wires that have no power are the c1,c2 wires from where you convert dpfi to mpfi i checked right up to the ecu plug and no power also the blue wire on the distributor itself has nothing
SlickEJ8
Aug 14, 2011 01:17 PM
efsedan556
May 19, 2011 08:37 PM
accord387
Oct 21, 2004 10:57 AM
1fst4
Jul 29, 2004 04:09 PM
GroundZer0
Audio / Security / Video
Dec 19, 2003 03:48 PM
