code 15 help
Old Aug 4, 2011 | 06:00 PM
SlickEJ8's Avatar
Default code 15 help
getting code 15.
year: 96
problem: the car would take a few secs to start. i was driving it around the block and it just lost power.. pushed it home.. it woulndt start at all, at this point. i pulled plug wire to cylinder 1 out and put it to ground (no spark).. checked the main reply, fuses, replaced the ign switch, the ignitor is good, plug wires are good, pulled both the ecu and back up fuses, replaced the coil.. any help please.. also its gettting power to the disturber.
Old Aug 4, 2011 | 06:23 PM
SlickEJ8's Avatar
Default Re: code 15 help
once it starts its fine.. nice idle, ect.. also while it was running i unplugged each wire.. their all getting spark
Old Aug 5, 2011 | 12:19 AM
SlickEJ8's Avatar
anyone?
Old Aug 5, 2011 | 05:18 PM
SlickEJ8's Avatar
updated... ign on ll (12.7 volts) to the disturber. then when cranking it loses power and drops to 0 volts.. any ideas?
Old Aug 14, 2011 | 12:15 PM
1HGEJ2's Avatar
u found the problem??
Old Aug 14, 2011 | 01:03 PM
lazlong's Avatar
You either have a bad ignition control module (igniter) or a bad wire/connection between it and the ECM or a bad wire between it and the ignition switch. I would start by checking connections at the dizzy then take it to Autozone and have it checked. You really need a service manual, all this stuff is in there.
Old Aug 14, 2011 | 01:17 PM
1HGEJ2's Avatar
the complete ignitor i from an another car. i thinks its the wire.
Chickenfcker
Dec 27, 2014 07:24 PM
DESTROYDCB7
Jul 10, 2011 07:13 AM
efsedan556
May 19, 2011 08:37 PM
civic89si666
11
May 31, 2009 11:55 AM
dviperbigt
Nov 5, 2004 08:01 PM
