skunk 2 im on gsr
anyone with skunk 2 im on their gsr.I have 00 gsr with skunk 2 im ,itr tb,comptech icebox/intake,with stock gsr cams.Im planning to upgrade to skunk 2 stage 1 cams later on,How much whp am i looking at.I also have a vafc 2, which i will leave the settings alone for now.
my car with almost the exact same mods as you ran like crap right after i put in the skunk cams. You will definately need to get it tuned to see the best results!
1.) Leave the settings alone.
2.) After installation, send your car to the dyno to get tuned. Your car won't run well after they just drop them in and you really won't see any power gains, they need to be tuned.
3.) You might aswell get some cam gears for some more tuning on the dyno to get the most out of those cams.
4.) Are you thinking about ECU chipping or atleast upgrading your valvetrain? Because those cams make power higher then your stock GSR redline and thats where they will get optimel performance.
5.) Im assuming you have a header back setup. But if you don't, you may want to think about that. Especially throwing in those cams, if you want to see good power.
once you answer some of that ill help you out more.
