Is the TPS or Throttle Position Sensor on the Integra Type-R ONLY good ON OTHER Type-Rs?
Old Jul 27, 2004 | 11:14 AM
.brad's Avatar
25 Year Member
Default Is the TPS or Throttle Position Sensor on the Integra Type-R ONLY good ON OTHER Type-Rs?
~ Or can I use ANY TPS?
My dad like to be involved with my car as much as he can and doesn't know what the **** he is talking about half the time and so he calls me today while some mechanic is telling him he's going to have to special order this thing.
I was under the impression that they were all the same and I just don't want him to get scammed.
Thanks in advance!
--b
Old Jul 27, 2004 | 11:22 AM
splitime's Avatar
Default Re: Is the TPS or Throttle Position Sensor on the Integra Type-R ONLY good ON OTHER Type-Rs? (.brad)
A TPS is a TPS, but you have to drill out or dremel slots in the OEM rivets. He probably is being told by a dealer that they need to order a new TB since the TPS is considered part of it.
Old Jul 27, 2004 | 12:22 PM
.brad's Avatar
25 Year Member
Thanks.
I don't know where my dad finds these places around town but my he put me on the phone with this guy who kept referring to him as 'my mechanic' and started asking me about the motor so he could sum up my knowledge or something, telling me how he was 'hooked up' with all the other parts stores in town and 'what he saw was...' so I drilled him on what computer app he was using because I had the Honda EPC and let him know me and my friend brian (thinkbrian) and I did the swap so he shut up about it and let me go. I immediately called my dad back and told him to just get his card and we would call him because I felt my source(s) aka Honda-Tech.com was much better than his. I guess he was trying to get my dad to order an entirely new Type-R throttle body.
I appreciate your advice, I saw in other posts that any could be used I was just making sure.
My car's still throwing a code 7 though so Brian's bringing third TPS on the way, hopefully it will work this time.
https://honda-tech.com/zerothread?id=939803
Old Jul 27, 2004 | 01:19 PM
splitime's Avatar
Default Re: (.brad)
All you have to do is slot the rivets with a dremel and you can screw the old one off. Then replace the slotted rivets with hex headed bolts (easier to adjust) and you can adjust the tps back to stock settings when you replace it.
Old Jul 28, 2004 | 02:22 PM
.brad's Avatar
25 Year Member
No dremel so I used a hack saw and did a pretty damn good job slotting them. It still throws the code and I haven't had a chance to test iit with a third TPS.
Hopefully tonight I'll have a chance at another.
Could it possibly be something other than the sensor? The wiring looks fine as it is constantly running 5.20 volts as measured through the multimeter and when I slide the sensor it got up to 5.30 and that's it!
Old Jul 29, 2004 | 08:12 AM
splitime's Avatar
Default Re: (.brad)
Isn't it supposed to be like .04 to .49v? Are you sure you didn't swap plugs between TPS and MAP up there?
Old Jul 29, 2004 | 10:06 AM
stevel's Avatar
Default Re: (splitime)
i believe the range is .5v (closed throttle) to 4.5v (WOT). the WOT voltage might be wrong but I know it's .5v closed.
s
Old Jul 29, 2004 | 07:09 PM
splitime's Avatar
Default Re: (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel &raquo;</TD></TR><TR><TD CLASS="quote">i believe the range is .5v (closed throttle) to 4.5v (WOT). the WOT voltage might be wrong but I know it's .5v closed.
s</TD></TR></TABLE>
You're right. I just went and double checked with one of my hondata logs.... WOT = 4.5V and closed = .5v.
Old Jul 30, 2004 | 12:07 AM
.brad's Avatar
25 Year Member
and the third TPS works!
Modified by .brad at 3:47 AM 7/30/2004
12
Aug 2, 2008 07:04 AM
nutball72
Nov 11, 2006 07:14 PM
GSRswapandslow
Aug 30, 2003 05:24 AM
SprayinCX
Aug 2, 2003 09:49 PM
