What timing belt for a tall-deck Dart block?
As topic says, what timing belt will fit on a tall deck Dart block? As this block has a 14mm taller deck than a stock B18 block the belt has to be over 1" longer to fit and tension correctly, if I'm not mistaken. Maybe a H22 belt will work?
Reason I'm asking is I'm planning an Allmotor build up this coming winter, and sending out my block to get it resleeved will cost $$$$$ as there's no places over here in Norway to do this kind of work, so I was thinking of getting me a Dart block instead. And then why not get a tall deck and build a 2,1L
I'm gonna be running Toda C cams so would prefer to use a Toda or Power Enterprise belt just for some peace of mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O »</TD></TR><TR><TD CLASS="quote">
depands on your water pump, LS waterpump, LS t-belt.
vtec water pump, B18c1/c5 timing belt.
curious, what crank are you using?</TD></TR></TABLE>
Plan on getting a 92mm or maybe a 95 mm Crower crank if i decide to go with a tall deck Dart block, combined with custom lenght rods to retain a stockish R/S ratio.
So what you're telling me is that a stock length timing belt will work? There is sufficient room for slack in the timing belt adj. to allow this?
I will get me a new ITR water pump for this build anyways as i have 115K km's on my current motor and will not cheap out and swap over parts like water and oil pump just to save a few $$.
Excellent
Excellent
you need a longer timing belt, Dart part # 67230001. Payn Technologies usually use a different water pump and pulley, though I don't know which ones. You can contact them at http://www.payntechnologies.com.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moxie »</TD></TR><TR><TD CLASS="quote">you need a longer timing belt, Dart part # 67230001. Payn Technologies usually use a different water pump and pulley, though I don't know which ones. You can contact them at http://www.payntechnologies.com.</TD></TR></TABLE>
Thanks, good to get correct info from the source
cyrix12
Jan 6, 2006 12:37 AM
EGTeK
Aug 3, 2003 01:37 PM
