What kind of spark plugs do you use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel »</TD></TR><TR><TD CLASS="quote">NGK </TD></TR></TABLE>
Are the bosch as good as the NGK spark plugs? Well i bought some bosch spark plugs. Kragen didn't have the ngk spark plugs in stock. So i went with the bosch spark plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMH22A »</TD></TR><TR><TD CLASS="quote">Are the bosch as good as the NGK spark plugs? Well i bought some bosch spark plugs. Kragen didn't have the ngk spark plugs in stock. So i went with the bosch spark plugs. </TD></TR></TABLE>
i was at the dyno and had bosch plugs in, swapped em for some ngk vpowers and there was nearly a 4 hp gain
wow, youve seen ngk's make 4 hp on the dyno? whoopty-doo. ive seen bosche platinums turn higher numbers than ngk's.
i also call bs at 4 hp on the dyno from changin the plugs out.
here is a link to dyno between bosch v. ngk; http://www.importreview.com/re....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10000rpm »</TD></TR><TR><TD CLASS="quote">stock typ-r plugs is the best cus is automatically 1 step colder from the original plug for your motor</TD></TR></TABLE>
Uhm, no, they aren't the best. Plug selection is completely dependent on motor setup, compression, etc.
civicracingteam
Feb 17, 2005 03:41 AM
