broken valve cover bolts
Old Jul 27, 2004 | 08:09 AM
ButterMule's Avatar
Default broken valve cover bolts
I got some broken bolts on my b16 valve cover... i broke two of them, they are two that go in the center of the valve cover, the ones that hold the plug cover down. Anyone got a solution or some new bolts?
Old Jul 27, 2004 | 08:20 AM
HatchBox's Avatar
Skoobie no more...
Default Re: broken valve cover bolts (ButterMule)
i did the same thing, take off the valve cover and unbolt the bolt, then order some from honda
i think you need number 20, i think the bolt runs about 5 bucks
Old Jul 27, 2004 | 09:41 AM
kid-honda's Avatar
I pulled some out of a D16 head when I needed some and they worked on my B.
Old Jul 27, 2004 | 09:51 AM
kur0ryu's Avatar
yeah, those bolts are pretty soft, especially on first gen b16as... I've done it 4-5 times, luckily I have another head to pull bolts from.
Old Jul 27, 2004 | 11:13 AM
Donkey85's Avatar
Default Re: broken valve cover bolts (kur0ryu)
a visit to you local pick and pull or to the local honda dealer will solve your problems if i remember right your only saposed to torque them like 10 or 12 inch lbs
Old Jul 27, 2004 | 01:02 PM
Smokinsax's Avatar
The Boot
ive done it once...its a snap to replace...
they are a 2-sided bolt, threads go down into the head and then the other threads go up and through the valve cover. Torque them at like 5 ftlbs, and the #20 is correct.
Jz6m
Jul 19, 2011 02:07 PM
flipwhip
Nov 19, 2006 11:07 AM
bartek_b
Apr 15, 2003 11:21 AM
crxaddikt
Sep 19, 2002 10:08 PM
TeamTooQuick
May 18, 2002 08:18 AM
