Problems you have had with this engine - Integra 1.8 Dohc Vtec 1994
What problems should I look out for, I am about to buy the above mentioned Integra 4door, with 80k miles. Lacquer is coming away from the rear bumper so price is reduced, I have someone I know who can repsray very well and will hope to get it redone professionally so it lasts 4 years easily....or more...
What should I watch out for, and check on car?
How do I know it is burning to rich?
Thanks Niaz
PS whatever else you think cheers!
Thanks Niaz
Is it stock? Ask the owner if the Tbelt and valves have been adjusted. Thats about it. There are no other problems that i can think of that'll be expensive to fix.
do a compression check also. I forget what numbers to look for
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedymon »</TD></TR><TR><TD CLASS="quote">Is it stock? Ask the owner if the Tbelt and valves have been adjusted.
do a compression check also. I forget what numbers to look for</TD></TR></TABLE>
honda says should be 135-199psi w/ max variance of 28 psi between cylinders. the most important thing is that the numbers are close together
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wallstreet »</TD></TR><TR><TD CLASS="quote"> I am about to buy the above mentioned Integra 4door, with 80k miles. hope it lasts 4 years easily....or more...
80K is a BABY for a b18. people have 130K on their engines and then TURBO them (good compression results are a must though)!
if your ****'s in order, that car can last you 10 years
bought my 94 at 89K, now have 171K, no oil loss whatsoever, VTEC'd everyday.
i have a 94 gsr....havent really had anything bad w/it....sunroof flew off going down the interstate...that was kinda wierd, cam seal was leaking but thats normal, everything else was just normal....like the radiator cracking.....bought it w/65k miles, now has 92k miles and running like new!....i did have to get the car repainted though.
