ECU question
Old Nov 26, 2001 | 10:14 PM
RedRacerCivic's Avatar
Default ECU question
Are ECUs supposed to blink once in a while just to show that it is working? Cause my ECU doesnt blink at all, the only time it lights up the LED is when i start my or turn on the ignition, but it only blinks once for half a second. Other than that, it doesnt blink.
Old Nov 26, 2001 | 10:36 PM
Blown90hatcH's Avatar
Default Re: ECU question (RedRacerCivic)
No, that is normal. The Ecu should flash the LED at start up and not again, unless you are throwing a code.
Old Nov 27, 2001 | 12:50 AM
[626]95-GSR's Avatar
exactly what he said. in other words, no blinky light = good. Blinky light = Bad.
If you ecu wasnt working, your car wouldnt even start.
Old Nov 27, 2001 | 01:07 AM
AfEn808's Avatar
New User
Default Re: ECU question ([626]Rj-SiHatchy)
anybody know whats up with my car sometimes the check engine light comes on when i down it on the freeway but if i turn my car off and turn it back on it doesn't come on.
Old Nov 27, 2001 | 09:11 AM
REDBARON's Avatar
Default Re: ECU question (AfEn808)
Just because the check engine light went off, it doesn't mean that the ecu is not throwing a code. Check the ECU because once the CEL comes on, then there will be a code on the ECU. The only way to make the code go away is to reset the ECU. But if the problem is not fixed, then it will come on again.
Old Nov 27, 2001 | 02:07 PM
JunkeeCrx's Avatar
New User
Default Re: ECU question (b16CRXfast96)
yeah. just get a jumper wire in there and look for a pattern. i don't have the proper codes though for the 91.
if you are looking for codes go to http://www.autolibrary.org put in your car info, and get the codes....
Old Dec 5, 2001 | 10:41 PM
zerospooon's Avatar
rene - dont worry about it - go out, get some sunshine - STOP STARING AT YOR ECU!!!!!!!!!!
Old Dec 6, 2001 | 11:45 AM
Cereal_Killer's Avatar
your good, don't worry about it. also..where the money you were supposed to get to me in the mail. at this rate it would have been easier for you to drive it up her then to mail it! JFWY..
Chris_Bye
Jul 10, 2004 12:10 PM
frostt3ch
10
Jun 22, 2003 11:09 AM
BigMig
May 10, 2003 06:01 PM
EF_LSVtec
Oct 31, 2002 07:38 AM
