Where is the light for the ecu number checks on a 2000 type-r?
Not sure if I understand your question. But if your looking to count the flashes for a trouble code, It is the check engine light that flashes.
Where is the light for the ecu number checks on a 2000 type-r? the ecu number codes
Hope that helped!
You have to jump a connector under the dashboard to see the flashes.
If you're going to do this, you should get a copy of the service manual. The procedure is described in the "Fuel & Emissions" section.
crxaddikt
Dec 1, 2003 09:23 AM
