Brake Service Lights Comes on Sporadically
Old Jul 27, 2004 | 03:46 AM
tarheelborn's Avatar
Default Brake Service Lights Comes on Sporadically
'00 Accord SE. Brake Service light comes on periodically early in the morning, then goes off after a few minutes. Pads and fluids look fine to me. What could the problem be?
Also, I have heard that the rotors need to be turned on an on-car lathe instead of being removed and then turned. Is this true? Is it hard to get the rotors off myself? Is a standard brake shop a safe place to get the rotors turned?
Old Jul 27, 2004 | 05:09 AM
2wickedtoyz's Avatar
Default Re: Brake Service Lights Comes on Sporadically (tarheelborn)
Q:'00 Accord SE. Brake Service light comes on periodically early in the morning, then goes off after a few minutes. Pads and fluids look fine to me. What could the problem be?
A:check your tail lights one might be out or not making a proper connection
this is not true it's not difficult to remove the rotors there are only 2 bolts holding the brake caliper and braket on there. as long as the brake shop knows what their doing. but you can buy rotors off of ebay cheaper and you can get the performanc set instead.
hope this helps
BelizeBlueHonda
Suspension & Brakes
Mar 16, 2017 10:08 AM
usdmftw
Mar 26, 2012 04:02 PM
a.wax
Sep 15, 2007 06:53 PM
seer_claw
Feb 24, 2004 08:13 PM
YipMan_Style
Oct 29, 2002 08:55 AM
