Boost H22 stock internals
Old Jul 26, 2004 | 11:09 PM
archmage's Avatar
Default Boost H22 stock internals
Hello.
I want to be able to run 12+ psi on an H22 engine, but on stock internals.
Question: Is there any way to strengthen this engine in any way (without resleeving)? I'm not sure if a blockguard or new pistons would help, but what would be the cheapest way to "get away with" a few extra pounds of boost, reliably?
I know the H-series has problems handling boost. From searching, I've discovered that the weakness can be attributed to the ringlands. I've also realized that the max recommended daily-boost level is around 7-8psi, but some people successfully run their engines above 10psi.
Goals: 300-350whp daily driven, and capability for 350+ for drag (if possible)
Thanks for any advice/tips here.
Edit: Damnit, forgot about H22's FRM sleeves...compatibile pistons may be harder to find...
Still - any help is appreciated, I'm not sure exactly WHAT would help the situation.
Modified by archmage at 8:30 AM 7/27/2004
Modified by archmage at 9:05 AM 7/27/2004
Old Jul 27, 2004 | 12:58 AM
flip1199's Avatar
Default Re: Boost H22 stock internals (archmage)
sure u can probably get that, but it might blow. especially tryin to get that 350 on a stock motor. why not just build it instead of tryin to boost as much as u can on stock motor and prayin that it dont blow? what fuel management are u planing on running? thicker headgasket?
Old Jul 27, 2004 | 10:41 AM
archmage's Avatar
Default Re: Boost H22 stock internals (flip1199)
Thanks for the reply!
I don't really feel like spending on a full re-sleeve and build-up. But I figure that if it blows, I'll just do it anyway. I'm not low on funds or anything; I'd just prefer a budget setup.
I was thinking about going with Uberdata or Hondata for tuning. (again, budget...so maybe Uberdata) I realize that much of boost-handling will involve tuning.
As for the headgasket - I wasn't planning on lowering compression, so if anything - just a stock-sized one - perhaps some ARP or AEBS head studs.
I'd be happy even with 10-11 psi daily and just 320+whp... I've experienced about 250 fwd, so I want something that will really struggle for traction (I'll consider suspension / chassis rigidity / bushings / tires / LSD... but still - best-value parts)
Any further thoughts?
Edit: Assume that I've found compatible forged pistons - solution?
Modified by archmage at 7:52 PM 7/27/2004
Old Jul 27, 2004 | 10:42 PM
archmage's Avatar
No one can tell me if anything will at least help in any way?
I've obviously searched - so I know it's not that... Does no one know?
I'd figure new pistons (if possible) would solve the ringland issue?
Thanks for any insight on this - I'll have to call someone up if no one answers...
Old Jul 27, 2004 | 10:52 PM
flip1199's Avatar
to solve the ringlands problem either dont boost at all or drop in forged pistons and sleeve it
Old Jul 27, 2004 | 10:59 PM
boosted lude's Avatar
What is the breaking point of a stock h22 in terms of HP not psi?
Old Jul 27, 2004 | 11:05 PM
archmage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">to solve the ringlands problem either dont boost at all or drop in forged pistons and sleeve it</TD></TR></TABLE>
Forged Pistons AND Re-Sleeve = solved
What about Forged Pistons compatible with stock FRM sleeves = Solved? or no
This is where the confusion lies...
Thanks, though.
Edit: And I'd estimate that the breaking point would be around 330-350whp - There was a guy who blew a rod at 379whp, but his ringlands were fine. He was fine up to that power level.
Modified by archmage at 8:24 AM 7/28/2004
Old Jul 27, 2004 | 11:46 PM
flip1199's Avatar
to my knowledge there isnt' any forged pistons that will work with stock sleeves.
Old Jul 28, 2004 | 01:59 AM
TurboTony's Avatar
I don't know to much about H22 to motors besides that they are not good under boost. My friend has a H22 motor in a EG hatch it was boosting three pounds. It had a direct built on kit (Max Rev). It was on 3psi and was dyno tuned on 3psi with a V-AFC by SFP. When he took the motor apart to build the buttom end. All of his cylinder walls had hair line cracks. Now, he has a block that is bored out, sleeved, pistions, rods and cometic headgasket. Tuned with Hondata and a bone stock head. His H-T name is H22hatchy if you want more information on the brands he used for pistions/rods/sleeves and how much power he is making now.
Old Jul 28, 2004 | 12:47 PM
archmage's Avatar
http://www.highaltitudeimports....html
According to that (Bottom of page, last 3 posts) - Wiseco makes FRM compatible forged pistons.
Edit: http://www.wiseco.com/PDFcatalogs/SC04-f.pdf --- stock bore. I wonder if those will damage the FRM sleeves...
And those hair-line cracks worry me...hmm - I may end up just resleeving anyway though...need to explore options
Modified by archmage at 10:26 PM 7/28/2004
Old Jul 28, 2004 | 01:40 PM
Pikachu's Avatar
Boosting 7psi not daily though. Seems ok. New built block already in my garage ready in case of the inevitable...
Drifter6508
Nov 3, 2009 09:27 AM
preludejones
Nov 27, 2007 02:23 PM
250Z_ORANGE_LUDE
Jan 23, 2006 06:10 AM
Corruption
May 8, 2005 06:24 AM
