Tire size
Old Jul 26, 2004 | 09:50 PM
civichater's Avatar
Default Tire size
I have a 92 lx accord and was wondering what is the widest tire that I can put on the stock 14X6 rims. I wanted to go with a 205/65/14, but dont know if they will rub.
Old Jul 26, 2004 | 10:55 PM
Starrman85's Avatar
Default Re: Tire size (civichater)
not sure if a 205 will fit on a 6" wide rim, but i got 215/45/17 on my 17x7's, and it doesn't rub at all in the front, and barely rubs in the rear, but only when i turn. i'm also on h&r sport springs, so its lowered. if your at stock height, i doubt you'd have a problem.
Old Jul 27, 2004 | 05:24 AM
TouringAccord's Avatar
H-T Order of Merit
You shouldn't rub. I had 205 wide Kumho 712's on 15x6.5 with a +55 offset and the tires didn't rub but the rim was real close to touching the knuckle. So I dought your going to rub the tire on anything. What offset is the rim anyway?
Old Jul 27, 2004 | 05:55 AM
2wickedtoyz's Avatar
this might help:
http://www.miata.net/garage/tirecalc.html
Old Jul 27, 2004 | 09:53 AM
pyrojeff's Avatar
Default Re: Tire size (TouringAccord)
205 might fit, but it'll look weird, like the tire is bulging. 195 would probably be good.
gramkrackers
24
Aug 2, 2012 12:39 AM
Platinum.Skillz
Oct 31, 2007 11:52 AM
betta285
May 14, 2007 06:10 AM
johnxboi
Apr 4, 2005 02:50 PM
Mr. Vapor
Jul 1, 2002 11:23 AM
