BREMBO or OEM rotors??
i don't know which ones to get for my teg.. either way it would cost me about the same so yeah.. which one would you guys recommend? and what exactly would the difference between the 2?
o yeah and its gonna be plain rotors not slotted or drilled or none of that stuff
and yes, i said it once, i'll say it again.. i'mma n00B!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patmcd »</TD></TR><TR><TD CLASS="quote">if you buying blanks, they are all relitivly the same. Your pad choice is much more critical.</TD></TR></TABLE>
Agreed.
Agreed.
Forreals....Autozone rotors work fine. If you wanna throw away those extra few dollars for brembo, go for it. But they wear and brake just the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 »</TD></TR><TR><TD CLASS="quote">Forreals....Autozone rotors work fine. If you wanna throw away those extra few dollars for brembo, go for it. But they wear and brake just the same.</TD></TR></TABLE>
are you also running autozone brake pads??
just installed brembo blanks and metal master pads that i bought from Importrp in the sponsors section. they grab a lot better and got rid of the annoying squeal i had with the raybestos pads that still had like 60% meat left. probably the main difference was the pads.
