Dyno tuned with pics! - Greddy 18G on 94 GSR
Old Jul 26, 2004 | 06:41 PM
Nihilation's Avatar
Default Dyno tuned with pics! - Greddy 18G on 94 GSR
Thanks to the HT search engine and some helpful heads from this site I finally got the car running correctly!
Steve Sakai was cool enough to drive up to Excessive Motorsport in Manassas today to tune my freshly boosted GSR. We got the car strapped down and he began to do his thing. Hondata that is. Base pull on 6psi was only 202hp which was tuned up to 212 a few runs later. From there we decided to throw on a manual boost controller which I had laying around and pump it up a few more pounds. We decided to go up slowly. Next mark on the map was to be 8psi. At this amount of boost the car made 232hp and 163tq. Final planned destination was 10psi, however we never made it there. We adjusted the MBC for more and more boost, however it never gave more than 8psi...which was weird. We attempted for more than 8psi several times and after the 3rd or 4th attempt we gave up figuring it may have been a sign to quit now...while I still have the stock clutch.
Odd thing you may notice is that the turbo doesn't reach peak boost till nearly 6k rpm. We're thinking that the wastegate actuator may not closing the door completely, causing late spool up times. We didn't really have the time to investigate...
Thanks again to Steve Sakai, VERY cool guy! On to the pics!
Modified by Nihilation at 11:41 PM 7/26/2004
Old Jul 26, 2004 | 07:24 PM
lanojp1's Avatar
nice man, you have a real clean looking ride..
stock internals im assuming?
Old Jul 26, 2004 | 07:35 PM
Nihilation's Avatar
Default Re: (lanojp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 &raquo;</TD></TR><TR><TD CLASS="quote">nice man, you have a real clean looking ride..
stock internals im assuming?</TD></TR></TABLE>
Thanks, and yes sir.
Old Jul 26, 2004 | 07:38 PM
Mag00n's Avatar
Default Re: (Nihilation)
Nice clean setup you have there. Looks to be very reliable.
Old Jul 26, 2004 | 08:11 PM
Charles B.'s Avatar
Default Re: (SICKSOLVTEC-T)
nice and clean setup/car
Old Jul 26, 2004 | 08:19 PM
GS-Rdriven's Avatar
Default Re: (CharlesInTurbocharge)
very clean ride man..is that the intake filter sticking out of ur engine bay?
Old Jul 26, 2004 | 09:43 PM
xJ.SLOTHx's Avatar
Default Re: Dyno tuned with pics! - Greddy 18G on 94 GSR (Nihilation)
congrats on your setup...im not trying to be a dick but that power output looks similar to that of an all motor setup.
Old Jul 26, 2004 | 09:44 PM
sheepey's Avatar
good **** bro
Old Jul 26, 2004 | 09:53 PM
npcanibus3's Avatar
Default Re: (sheepeg3)
good job man and nice wheels :D
Old Jul 26, 2004 | 09:58 PM
SiBirdie's Avatar
Default Re: (npcanibus3)
ditto, keep it clean and not jdm whoring it out to the max. I like it.
Old Jul 26, 2004 | 10:01 PM
Sprockets's Avatar
Glad you finally got everything worked out! Nice car! Who did your downpipe, and what exhaust did you go with?
P.S. Sell me your seats!
Old Jul 27, 2004 | 07:26 AM
Nihilation's Avatar
Default Re: Dyno tuned with pics! - Greddy 18G on 94 GSR (B16A Grenade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A Grenade &raquo;</TD></TR><TR><TD CLASS="quote">Glad you finally got everything worked out! Nice car! Who did your downpipe, and what exhaust did you go with?</TD></TR></TABLE>
The downpipe is the stock Greddy straw. From there on back it's Kteller's stainless steel 3" piping with a flexpipe and an 18" resonator...SRT-4 style.
Old Jul 27, 2004 | 08:04 AM
MachAF's Avatar
Default Re: Dyno tuned with pics! - Greddy 18G on 94 GSR (ian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian &raquo;</TD></TR><TR><TD CLASS="quote">congrats on your setup...im not trying to be a dick but that power output looks similar to that of an all motor setup.</TD></TR></TABLE>
your joking right?
Old Jul 27, 2004 | 08:10 AM
RIPracing's Avatar
Default Re: Dyno tuned with pics! - Greddy 18G on 94 GSR (MachAF)
real nice man, that good for that turbo...
Old Jul 27, 2004 | 11:00 AM
Sprockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nihilation &raquo;</TD></TR><TR><TD CLASS="quote">The downpipe is the stock Greddy straw. From there on back it's Kteller's stainless steel 3" piping with a flexpipe and an 18" resonator...SRT-4 style. </TD></TR></TABLE>
How long did it take for Kteller to do the work for you? SRT-4 style? You need dual tips for that!
Old Jul 27, 2004 | 11:24 AM
ash.zero's Avatar
nice clean car! manassa? i'm centreville!
got a pic of engine bay close up?
the boost does build a lil too slow. definitely check for exhaust leaks (gaskets) and wastegate leak. good luck!
Old Jul 27, 2004 | 11:57 AM
Rollo Lawson's Avatar
Default Re: Dyno tuned with pics! - Greddy 18G on 94 GSR (ash.zero)
heres my boys dyno. he made much more power than that out of his b16 with the same kit, psi, im, injectors and all. the only difference is the d.p.
https://honda-tech.com/zerothread?id=925589
those numbers seem like weaksauce to me, but, the car is clean.
Modified by B16C1 at 8:14 AM 7/28/2004
Old Jul 27, 2004 | 01:42 PM
patdemps's Avatar
Default Re: Dyno tuned with pics! - Greddy 18G on 94 GSR (B16C1)
Looks nice, I like your ride.
More close ups on the engine bay
Old Jul 27, 2004 | 01:47 PM
Nihilation's Avatar
I think the downpipe adds a good bit of power on the Greddy kit.
I added a manual boost controller and no matter what I set it to, it wouldn't boost higher than 8psi. Today, going by a Spearco mechanical gauge, I can't get more than 6 out of it for some reason.
Old Aug 10, 2004 | 06:19 PM
95gsrturbo's Avatar
HAHA
have you searched greddy posts, check my name in threads ive posted, evidently this is a common issue with the setup on that WG.
cant figure it out!
No offense but i find this relieving, ive given up on trying to make more power out of this kit, my max is now 270 out of 15 psi that just peaks then falls back to a fluttering 9psi
good luck but im switching to different mani and exernal gate.
good numbers though
Old Aug 10, 2004 | 06:35 PM
2SlowDC's Avatar
those #'s do seem kinda low for the setup
Old Aug 10, 2004 | 06:39 PM
Ri5e's Avatar
Default Re: (95gsrturbo)
Wow, you're boosted! I remember when you just joined H-T last year after getting rid of your Stang ...
Old Aug 10, 2004 | 07:26 PM
Nihilation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrturbo &raquo;</TD></TR><TR><TD CLASS="quote">HAHA
Wow. My post is back, haha.
After I added the Profec B I can boost higher without any issues. My current problem is that somehow I think the wastegate actuator keeps coming out of adjustment. At first it wouldn't build boost until 5k+ RPMs. Adjusted the wastegate and it fixed it, 5psi by 4k rpm. Today I started noticing less torque down low so I did a test and the Profec B registered 2.8psi at 4k rpm. Guess I need to adjust it again....if not, hope its just a loose hose.
My biggest problem was burning off my dipstick gasket. It caught fire going ~130 down the front straight at Summit Point.
Luckily it put itself out but left some burn marks on the heatshield and block. Got a new dipstick however I can't seem to bend the tube away from the turbo manifold. ...so I can see this happening again.
Old Aug 10, 2004 | 07:28 PM
Nihilation's Avatar
Default Re: (BG Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BG Boost &raquo;</TD></TR><TR><TD CLASS="quote">Wow, you're boosted! I remember when you just joined H-T last year after getting rid of your Stang ... </TD></TR></TABLE>
Some days I miss the stang...oh well, "Out with the old, in with the new".
Old Aug 10, 2004 | 09:16 PM
dc0166's Avatar
nice, same numbers as my buddys car
