gsr b16 head?
Old Jul 26, 2004 | 10:48 AM
boostin4door's Avatar
Default gsr b16 head?
was wondering if the compression would be higher lower or the same using a gsr block with b16 head.. and a stock head gasket??.. ive heard a couple of turbo guys going with gsr block and b16 heads to lower the compression but, they dont use stock head gaskets either....anyone have the spec gsr/b16 lemme know thanks.
Old Jul 26, 2004 | 10:56 AM
crxgator's Avatar
Default Re: gsr b16 head? (widebodyjaeg16b)
i could have sworn if you put a gsr head on your b16a it would raise compression so in that sense if you do vise-versa it would lower compression...
it will lower it .2:1 according to c-speed...
Old Jul 27, 2004 | 06:45 AM
any one else?
Old Jul 27, 2004 | 06:53 AM
crxgator's Avatar
what kind of specs?
its already stated that it will lower your compression...
Old Jul 27, 2004 | 08:46 AM
Deetz's Avatar
Crazy Honda Guy
Its the gsr head that has the higher compression due to the smaller square quench area. The B16 has a more open round quench area which lowers the compression a touch, but of course can be changed with different thicknesses of headgaskets.
hatchet_honda
Jul 6, 2009 09:27 AM
spidy3
Jun 4, 2008 05:44 AM
mR. Vash
Nov 20, 2004 01:58 AM
X2BOARD
Nov 7, 2002 04:37 PM
blkDOHCsol
Sep 25, 2002 09:06 PM
