Recommended Brakes?
Old Jul 26, 2004 | 09:49 AM
ursino2's Avatar
Default Recommended Brakes?
Hi,
I have about 20K miles on my 03 accord 4-cyl EX, and I wanted to know what you guys recommend for replacement brake pads? I won't need them for a bit since I don't race it and don't do hard braking with it; I'm a pretty easy driver. I talked to one of my friends who recommended Brembo or kevlar brake pads as replacements. For pads, or pads & rotors/discs, what is recommended for a popular car like this, but for someone who wants to use high-quality brakes? Also, do I need to get a new ABS Sensor with any new set of brakes? I'd rather buy them and take them to my mechanic, who would gladly allow me to bring in the parts. I checked out http://www.bmaparts.com and they didn't have much for newer Accords.
Thanks
Frank
Old Jul 26, 2004 | 11:38 AM
ursino2's Avatar
Default Re: Recommended Brakes? (ursino2)
bump
Old Jul 26, 2004 | 11:46 AM
89_LXi's Avatar
Well OEM pads work great, but seem to dust alot (at least the OEM Nissin ones I had on before). Right now I have EBC Greenstuff, which is a low dust Kevlar type pad, and they've worked fantastic so far.... had them on for about 10k(?) miles. Still grip real well and, although they do still dust some, not nearly as much or as quickly as the OEM did. A buddy of mine swears by AEM pads, although I've never tried them myself, I know he knows his stuff so they must be good too. The only thing I don't like about using aftermarket pads instead of OEM is that they never seem to fit exactly right like the OEM do, and make some strange noises.
Old Jul 26, 2004 | 11:53 AM
accordselux's Avatar
Me Gusta History
Default Re: Recommended Brakes? (89_LXi)
If you dont race a lot and it's a daily driver, you don't want metallic pads, like Axxis Metal Masters. They'll squeak a lot and drive you crazy. AEM pads are good, also look into raybestos and some of the other Axxis lines of pads
Old Jul 26, 2004 | 11:55 AM
phoenixitc's Avatar
Tirerack.com has Brembo front blank rotors. AEM pads are good.
Old Jul 26, 2004 | 12:17 PM
Crono139's Avatar
Axxis Ultimates.
Old Jul 26, 2004 | 01:34 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: Recommended Brakes? (Crono139)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crono139 &raquo;</TD></TR><TR><TD CLASS="quote">Axxis Ultimates.</TD></TR></TABLE>
Those are the ceramic ones, correct?
Anyhow, pads from the dealer, NAPA, and pepboys/autozone will give you the experience of brake fade, pretty fast. From what I remember, AEM are good and they don't dust a lot. However, I don't think they have that warning noise to inform you that the brake pads are running low...so check up every once in a while so you don't cut the rotors. A few thousand miles ago, I installed PBR's or Axxis Metal Masters. They are very good, but squeak a hella lot, and cause massive amounts of dust. My black rims are turned clay red/brown.
My next set of pads will probably not be the PBR, but the EBC Greenstuff. Gotta try them.
Old Jul 27, 2004 | 04:18 PM
ursino2's Avatar
Default Re: Recommended Brakes? (-Bionic-)
Hm, ok, so out of all these brands, are there websites where I can fit them to my Accord? No idea where to buy these aftermarket pads and bmaparts.com has nothing for newer Accords right now.
Thanks all, for the great info!
Old Jul 28, 2004 | 07:10 AM
-Bionic-'s Avatar
Former Sponsor
Sponsors forum, ebay...search on google.
Old Jul 28, 2004 | 09:45 AM
89_LXi's Avatar
I got my Greenstuffs at http://www.tirerack.com
dc2LS
Jul 29, 2010 09:14 AM
civic710
Honda Civic (2006 - 2015)
12
Mar 19, 2009 08:08 PM
sIcWiTiT
Sep 26, 2002 12:28 PM
mikeSONICGSR
Dec 10, 2001 03:12 PM
WuShu
May 18, 2001 12:43 PM
