Compression b16a2. What the...####
Old Jul 26, 2004 | 04:15 AM
Froggin's Avatar
Default Compression b16a2. What the...####
Ok after getting realy weird numbers from getting my car compression tested at the dealer I decided to get my own compression tester.
My results..
Cyl 1: 200
Cyl 2: 190
Cyl 3: 165
Cyl 4: 215
I retested several times.
I am realy concerned about nr 3. I did have had an issue about nr3 in the past. I brought my car to a shop to get my valves adjusted and to change the timing belt. They didn't bolt down the bolt of the nr3 valve(dont know intake or exhaust) correctly so on my way home my valve starts ticking. Immediately turned around and went back to the shop. Removed the valvecover and found a bolt has went totally loose. And was dancing on the valve. The shop said nothing was damaged.
Could this low compression be a result of that?
Some notes:
I tested according to: http://www.c-speedracing.com/h...t.php
For the curious people the dealer results were
But I have doubts that they actually tested my car.
Cyl 1: 155
Cyl 2: 152
Cyl 3: 168
Cyl 4: 170
Edit ** Its a stock european b16a2, standard compression.
Modified by Froggin at 2:08 PM 7/26/2004
Old Jul 26, 2004 | 10:44 AM
Big Ern's Avatar
Default Re: Compression b16a2. What the...#### (Froggin)
1-How it the temp on the motor
2-when you smash the gas do you get much smoke or more than normal
3- The hell with that place and get a leak down test done on that motor, I think you may have a bent valve...
good luck, let me now
Old Jul 26, 2004 | 02:11 PM
Froggin's Avatar
Default Re: Compression b16a2. What the...#### (Big Ern)
1/ The temp is normal
2/ No, no smoke when slamming on the gas. I do have smoke when releasing the pedal. But that is an indication of the valve seals isn't it? Or maybe because of a bent valve?
3/ Thats what I said to, I never come there again!
So the valve could be the problem of the low compression!?
I think I will do the leakdown.
Thank you for your input
Old Jul 27, 2004 | 05:15 AM
Big Ern's Avatar
I hope its a easy fix for yah, and I hope its the problem. But most likely is.
Good Luck Dude...
egb18c5
35
Apr 11, 2013 03:58 AM
b18-crx
Apr 22, 2009 08:16 AM
acman1
May 21, 2007 12:06 PM
CNSK
Apr 10, 2005 08:54 AM
LostGsr
Jun 15, 2001 12:29 PM
