WTT: My JHP/Katman chipped P28 for stock OBD1 PR3 or P30 (So.Cal)
Old Jul 25, 2004 | 11:27 PM
kNOwLedGeDA9
Guest
Posts: n/a
Default WTT: My JHP/Katman chipped P28 for stock OBD1 PR3 or P30 (So.Cal)
I am looking to trade my JHP/Katman FFS.1.DOHC (this is an older program back in the JDMHONDAPARTS.com era) programmed OBD1 P28 ECU for any stock OBD1 PR3 or P30 B16A ECU. The ECU is in good working order, with VTEC at 5,200RPM and revv limiter at 8800. It is in perfect working condition. The programming ALONE was $160, so steal this from me. I am located in San Diego but am wiling to do this in the LA or OC area.
Old Jul 25, 2004 | 11:58 PM
kNOwLedGeDA9
Guest
Posts: n/a
Default Re: WTT: My JHP/Katman chipped P28 for stock OBD1 PR3 or P30 (kNOwLedGeDA9)
ttt
Old Jul 26, 2004 | 12:43 AM
blubyyou2000's Avatar
hey man ive got a p30 ecu ...im located in alabama ...if you wanted to swap ...what all does the program consist of ...?
Old Jul 26, 2004 | 11:33 AM
kNOwLedGeDA9
Guest
Posts: n/a
Default Re: (allmotor91crx)
Damn all the way in Alabama! I'm not sure if I can do the shipping ordeal for the ECU because I have to see if there is an ECU that I can use during the downtime. I'll see what I can do. The program itself is different, as Katman has 3 different stages under his new program called OBD1.MGN. The program that i have is an older one, pre website change called FFS(FF-Squad).1.DOHC. It is more that likely comparable to either stage 2 or 3. To see what the stages consist of take a look @ http://ecu.ff-squad.com.
If anyone in So cal wants this jump on it.
Old Jul 27, 2004 | 01:31 PM
kNOwLedGeDA9
Guest
Posts: n/a
Default Re: (kNOwLedGeDA9)
bizzump
Old Aug 4, 2004 | 01:14 PM
kNOwLedGeDA9
Guest
Posts: n/a
tttttttttt
Old Aug 10, 2004 | 01:41 AM
kNOwLedGeDA9
Guest
Posts: n/a
ttttttt
Old Aug 12, 2004 | 12:40 PM
kNOwLedGeDA9
Guest
Posts: n/a
bump
Old Aug 24, 2004 | 10:09 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGeDA9 &raquo;</TD></TR><TR><TD CLASS="quote">Damn all the way in Alabama! I'm not sure if I can do the shipping ordeal for the ECU because I have to see if there is an ECU that I can use during the downtime. I'll see what I can do. The program itself is different, as Katman has 3 different stages under his new program called OBD1.MGN. The program that i have is an older one, pre website change called FFS(FF-Squad).1.DOHC. It is more that likely comparable to either stage 2 or 3. To see what the stages consist of take a look @ http://ecu.ff-squad.com.
If anyone in So cal wants this jump on it.</TD></TR></TABLE>
Just some FYI...
The program you have is what I sell now as the stage 3 OBD1.MGN program.
hondateg10
Mar 25, 2007 03:50 PM
MrEG6er21
Feb 20, 2005 11:32 PM
endlessdv
Jan 31, 2005 05:39 PM
