Fuel injectors - how to clean
How do you know when your fuel injectors need cleaning?
Is it best to put cleaner in the gas tank or to remove the injectors and clean them?
Is it difficult to remove each injector to clean?
Run the car til on empty then put in 2 gallons and put 2 things of NOS racing octain booster and I promise they will be cleaner but I dunno the effects of this on the engine I also dont know if this will harm any thing and I have not tested it I am just a post ***** hehe nah but just throw some injector cleaner in your gas tank.
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Go to the store and buy the Chevron Techron fuel cleaner. Not the ProGard stuff but the actual "Techron" cleaner. A friend at Honda says the Honda Engineers swear by the stuff. I use it a couple times a year even though the bottle says to use it every 3000 miles or something.
Cleaning it out by hand is probably a good idea every once in a while. The only problem is that you can't get inside the injector itself to clean the internal parts. That's where the fuel injector cleaner in the tank deal comes in. Or sending them to RC engineering to have them cleaned professionally.
There aren't any really bad sides to an in-tank cleaner. Just follow the directions on the bottle. Most will have you put it in at a near empty tank and have you drive around a bit before your next fill up. That way you get more of a concentration of the cleaner flowing through the injectors. Good luck!
snap-on has this neat little contraption.. it screws on after the fuel filter.. you disconnect your fuel pump and then fill in the container with half chevron's techron and the other half chem-tool injector cleaner. then just start it up and the car will run off of the cleaning solution.. just let it idle 'til it runs out. not only does it give your injectors a nice thorough cleaning but it also cleans the intake valves and the combustion chamber. you can find it on snap-on's webpage somewhere.. if it's too much cash maybe you could find a shop that'll do it for you
How about Redline fuel treatment? I just bought a bottle today at pep boys for around 5 bux. Redline is supposed to be good, so why not their fuel treatment?
this is the correct way to clean the injectors!
Many shops will do this for you, but they tend to charge like $80, but it is a full fuel system clean. The bottles are good for maintenance in between these cleanings.
sorry about that.. haven't been on the board for a while.. here's the link:
http://buy.snapon.com/catalog/pro_de...re&dir=catalog
i almost laughed out loud when i saw the price!!! maybe you could charge all of your friends to clean their injectors
Yes, I saw this item on the Snap-On page, but it is nothing like was described above. I was looking for something that I place cleaning fluid in and then running that through the injectors with the fuel pump disconnected. The item on the web page above seems to be a high pressure air cleaner.
Dont you guys think that it needs to have some sort of pressure to force the cleaner through the injectors? Im guessing this is the device everyones talking about. You need fuel pressure to make your car run....
I recently took out my injectors and dropped them off at RC to have them cleaned and balanced since I had about 95k on the car. When they checked the injectors, they found that hey were perfectly clean and balanced too and just charged me 40 for the check. Not bad for 95k. I've used the redline stuff about 3-4 times over the life of the car and I guess it works. But if you have massive buildup I dunno if it would be effective enough.
movingIIshadow
30
Feb 29, 2020 07:36 AM
EK45VTi
10
Sep 21, 2004 07:03 PM
