GS-R head removal?
Old Nov 26, 2001 | 05:36 PM
jteasy's Avatar
New User
Default GS-R head removal?
I am going to rip off my head tomorrow, and need a little help. Could anybody that has done this before and got snagged on something and later figured out it was only something small, share it with me, so I wont make the same mistake. I could also use some diagrams and step by step instructions for removal of the head, intake manifold, distributor etc... thanks, need asap.
Old Nov 26, 2001 | 06:50 PM
nfn15037's Avatar
Default Re: GS-R head removal? (JTEASY)
Heres some help: DOnt do anything until you get a Helms manual or something like that, unless you have done this already, which i doubt by the sound of your post. Its going to save you a lot of headaches and time to have a manual.
Old Nov 26, 2001 | 06:51 PM
immortal's Avatar
Banned
Default Re: GS-R head removal? (nfn15037)
yeah, you need a helms manual
the intake manifold bolts are a bitch to take off. also underneath the car theres a bracket thats holding the manifold down. umm
get a helms or dont even try it
Old Nov 26, 2001 | 06:54 PM
nfn15037's Avatar
Default Re: GS-R head removal? (immortal)
That bracket is the biggest piece of **** ever, grr, pisses me off thinking about it.
Old Nov 26, 2001 | 07:00 PM
gsr camel's Avatar
get a good manual will save you Asp loads of time!
Twanks
Old Nov 26, 2001 | 07:07 PM
jteasy's Avatar
New User
Default Re: GS-R head removal? (gsr camel)
I got a haynes manual, and found step by step instructions and information on removal of the intake manifold mount, but do I need to remove it if I am not going to remove the intake manifold, I plan on just unbolting it from the head, I am not sure if it is possible to remove the head without moving the intake manifold out of the way. thanks for the help.
Old Nov 26, 2001 | 09:27 PM
GTEater's Avatar
you dont need to remove the intake manifold........i pulled my head off with the mainifold, tb, and upper header still on.......there is a bracket underneaththe IM so you might need to unbolt that.........should be easy without the oil filter on.....same with the lower IM bolts
Old Nov 27, 2001 | 11:33 AM
jteasy's Avatar
New User
Default Re: GS-R head removal? (GTEater)
I I should drain all the fluids before, oil and antifreeze. I just need the head so if I left the intake and exhaust manifold on then, I would have to disconnect all of their wires and cables and hoses.
Old Nov 27, 2001 | 12:01 PM
GTEater's Avatar
its alot easier to disconnect the wires, and hoses from the IM than it is to disconnect the IM from the head........once the head is off with the IM and exhaust manifold, taking them off the head is a piece of cake(2 min)
Old Nov 28, 2001 | 08:25 AM
jteasy's Avatar
New User
I removed the head last night, but I just kept all the hoses and wires on the intake manifold connected, and I removed all of the bolts from the intake manifold to the head, and the three on the bracket for the intake manifold. Then I removed the b-pipe from the catalytic converter, and then removed the bolts from the head to the exhaust manifold, other than the timing belt and distributor, there wasn't much else. However, I did be accident remove the wires from from the O2 sensor on the cat, not the plug, but the wires came out of the plug, and I was wondering if anyone had a diagram of which color wire goes into which of the plug holes, or if somebody could crawl under their teg and check it for me, thanks.
sayanything
Sep 9, 2010 10:37 PM
Berry
Sep 17, 2007 10:17 AM
ZexyAccord
Dec 19, 2004 02:20 AM
chrisb
Jul 18, 2003 10:38 AM
fiebru1119
Jan 26, 2002 10:24 AM
