mcmaster carr vacuum manifold installation ok?
I removed the check valve for the brake booster vacuum line and placed the manifold inline there. is this an ok place for it??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsedan »</TD></TR><TR><TD CLASS="quote">im not really sure actually</TD></TR></TABLE>
no its not ok...
put that check valve in or you could end up w/ no brakes...
no its not ok...
u want to run the manifold before the check valve if your following the vacuum hose to the brake booster.. so closer to the engine..
and you can run it inline or T it off.. i teed mine off and it works out well.. im happy with it..
thanks for your help, im going to run it inline because i bought two of the nipples, not the 1/4" brass plug
crxd16
Mar 12, 2008 03:26 AM
djnikko
Nov 5, 2004 08:02 AM
