crx camber kit problems
i gotta 88 crx with H&R 1 inch drop oe sport springs and koni yellows. I installed a set of Ingalls adjustable camber kit for the front tires myself a bout 4 months ago because i didnt want any premature tire wear due to negative camber. but now i have camber wear. could the tire wear be due to me not getting the car to an alignment shop to adjust toe or caster before or after i installed the kit???
I would bet you WOULDNT have uneven wear if you DIDNT install the camber kit and not get it all properly adjusted and aligned. Besides, you dont really need a camber kit with that set up. I have two crxs... one with the exact same shocks/springs as you. No camber kit. Other crx is even lower on tokico blue and gc coilovers... no camber kit, and no uneven wear.
