cheap place for axles???
Old Jul 25, 2004 | 08:48 PM
cd5_2NR's Avatar
Default cheap place for axles???
just wondering where a cheap place was to replace your axles...
i called around and so far pepboys will do it for...
69.98 for the axle...life time warranty
90.00 for labor...
is that any good...its cheaper than a few other places that i've called...some places want 99.00 for 1 axle...
Old Jul 25, 2004 | 10:08 PM
brads94accord's Avatar
i paid like 80 dollars or maybe a little less for a passenger side axle. i replaced it myself in about 45 minutes. all you have to do is remove the 36mm axle nut, you will need a breaker bar and about a 3 foot pipe extension. then remove the 17mm bolt that attaches the shockfork through the LCA. then remove the cotter pin on the castle nut under the lower ball joint.remove the 17mm castle nut use a 2 jaw puller and pop the lower ball joint out. this tool was like $20 from advance auto parts. drain tranny fluid. then just have someone bang the old axle through the hub while you pull. (u dont have to have two people, i did it myself.) then use a prybar and pop the axle out of the tranny. then place new axle in, make sure you give it a firm push until it pops into place, then installation is reverse of removal.
Old Jul 27, 2004 | 02:05 PM
cd5_2NR's Avatar
Default Re: cheap place for axles??? (CD_5)
the cheapest i found was 149.00 with labor..and thats with a life time warranty...i guess i could do it myself but i got a shortage of time on my hands...it should be done by friday...
ugandaHonda97
Dec 15, 2010 12:59 PM
sony224422
Jul 7, 2007 03:29 PM
rasinhell
Jan 13, 2005 09:52 PM
FlyZlow
18
Jan 5, 2005 08:21 AM
kefka
Jul 16, 2004 03:34 PM
