Name this b16 part! (with photo)
This is low on the firewall side of the engine, on what appears to be the tranny.
It has a 3 pin harness on it:
Black
Yellow
Yellow/White
My Si harness doesnt have the plug for it. What is this?
Black
Yellow
Yellow/White
yep it's the vss, you can always just swap your old vss, it may look smaller than this one but it fits in the same way. Just use your old one. If you still have it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phan »</TD></TR><TR><TD CLASS="quote">yea, if you're going to throw it out you could always send it to me.
so i can use this one, if i have an sir cluster?
</TD></TR></TABLE>so i can use this one, if i have an sir cluster?
"a 94-01 integra VSS works. You need an electronic VSS. 1 power, 1 ground, 1 signal, essentially the power and ground are straight forward. The signal will go from the VSS to the ECU, then to your cluster."
Yes it will qork. if you don't have the clip that connects to it then you can use female wire connectors and just stick them on the male ends on the VSS. The trick is trying to figure out which pins have which functions.
-James-
-James-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">its a flux capacitor.....the necessary item for time travel......what do i win?</TD></TR></TABLE>
a cookie?
a cookie?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">its a flux capacitor.....the necessary item for time travel......what do i win?</TD></TR></TABLE>A date with my *****!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arthur »</TD></TR><TR><TD CLASS="quote">A date with my *****!</TD></TR></TABLE>
quite possibly the most gay thing i have ever seen on H-T
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 496cutlass »</TD></TR><TR><TD CLASS="quote">Just go get a mechanicle unit from an 89-90 integra ls! why bother with all the wiring when you can get a direct replacement?</TD></TR></TABLE>uhhh... duh he's useing a JDM cluster which requires a electric VSS, and it's 90-91 Integra, the 89s had D16A1s
blackoutvtec845
Apr 6, 2014 12:48 AM
94ej1civic
Jan 18, 2011 04:49 PM
GSR-EG-92
Transmission & Drivetrain
Oct 12, 2008 10:20 PM
