Lighting Problem...
Old Jul 25, 2004 | 04:00 PM
DC231 Sean's Avatar
Default Lighting Problem...
My left high beam is out. I tried a new bulb but no luck. I checked the connections near the bulb and they seemed to be fine. The 40A fuse in the engine bay fuse box is all right as well otherwise I would not have any headlights. I do not know if there is a fuse under the dash due to the fact when I bought the car used it was missing the cover with the chart on it. If anyone has any ideas I would appreciate it.
Old Jul 25, 2004 | 04:27 PM
Ill's Avatar
Ill
Default Re: Lighting Problem... (ITR3)
:Edit: My memory is faulty.
Low beam fuses under the dash are right side of the block (passenger side), middle row, the two 10a at the end. L is last one, R is second to last.
High beams are driver side, bottom row #4 & 5 spots in (towards right), 10a, R is #4, L is #5
If you have a voltmeter, check for voltage on the leads to the bad light.
Further edit - Ghetto diagram:
<---Driver side ------ Passenger side --->
<top - steering wheel>
Fuse: ...1 ..2 .3 ..4 ..5 .6 ..7 ..8 ..9 .10 11
Row 1 [ ] [ ] [ ] [ ] [ ] [ ] [ ] [ ] [ ] [ ] [ ]
Row 2 [ ] [ ] [ ] [ ] [ ] [ ] [ ] [ ] [ ] [R] [L] <--- low beams
Row 3 [ ] [ ] [ ] [R] [L] [ ] [ ] [ ] [ ] [ ] [ ] <--- high beams
<bottom - pedals>
Modified by Ill at 5:41 PM 7/25/2004
Old Jul 25, 2004 | 06:08 PM
uNF$@#!'s Avatar
Default Re: Lighting Problem... (Ill)
theres definately a headlight fuse for both left and right in the driver side fuse box.
Ill's diagram looks about right.
Old Jul 26, 2004 | 10:17 AM
DC231 Sean's Avatar
Thanks for the help. The left high beam fuse was blown so i replaced it and it blew again. So i replaced it again and that fuse blew as well. Any ideas why this is happening?
Old Jul 26, 2004 | 10:20 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (ITR3)
Have you tried a higher rated fuse?
Old Jul 27, 2004 | 07:49 AM
Ill's Avatar
Ill
Default Re: (ITR3)
If you have non-stock bulbs, or HID's, you might consider a higher rated fuse (15a). However I'd be looking for a short. Start checking any areas where there's been damage or work lately, or any spots where it looks like the wiring has been messed with. Otherwise, work backwards from the light following the wire harness. Also check where the wires connect to the back of the fuse block.
:edit: with HID's you may even need 20a. However check you have these first. If not, going to a higher rated fuse will just melt your wiring. Find the short instead.
RP215.
Jul 13, 2009 02:43 PM
basiceg6
May 5, 2009 07:46 AM
not-a-stang
Apr 9, 2008 07:50 AM
asubennett
Aug 27, 2004 10:13 AM
littledan
Jun 10, 2003 12:15 AM
