Fuel injector cleaner good or not?
Old Jul 25, 2004 | 03:53 PM
fab's Avatar
fab
Default Fuel injector cleaner good or not?
We see all kinds of fuel injector cleaner to put in the gas tank of the car. They range from 3$ to 25$. Do any of these brands make a difference on the lude?
Old Jul 25, 2004 | 04:02 PM
kablamo's Avatar
Default Re: Fuel injector cleaner good or not? (fab)
i'd use them at most once a year and use the midrange to relatively cheap stuff.
they are all the same - "petroleum distillates" in the ingredients.
too much will wear our your injector seals and deprive you of your money
Old Jul 25, 2004 | 04:47 PM
delguiner's Avatar
Default Re: Fuel injector cleaner good or not? (kablamo)
try seafoam in your fuel tank... ive used it with incredible results... you should try it too!
Old Jul 25, 2004 | 05:46 PM
fab's Avatar
fab
Default Re: Fuel injector cleaner good or not? (delguiner)
I am not familiar with "seafoam". where can I find it?
How much to put? What frequency?
would it correct my poor performance car problem (hic up while accelerating when I press the gas pedal all the way too quickly).
See this thread for details: https://honda-tech.com/zerothread?id=935167
Old Jul 25, 2004 | 05:53 PM
delguiner's Avatar
Sea foam could probably help. I just finished using it on my 1992 prelude SR (200,000km), my friends 97 civic SI (140,000km) and my 2000 Maxima (170,000km) and it works great... really helped me with the idle and very smooth acceleration, along with renewed power! i suggest you get some....
Now trouble is you live in Quebec like i do, so they dont have the product here... i heard of only a couple of places in Ontario and all over the states. What i did was ordered from someone i knew in the states and had it shipped over here...
What you can maybe do is go on ebay and search for it...
I also suggest you read up on the product. Do a search here for "sea foam or seafoam" and you should get a lot of hits with ppl talking about the product and what it does and how you should do it
try reading up on it over here too http://www.seafoamsales.com
hope this helps out man!
Old Jul 25, 2004 | 07:02 PM
fab's Avatar
fab
Thanks for the info.
The Honda dealer says that the car engine does not need to be cleaned at only 70000 km ? Is he wrong
I do not know enough mechanics to "play" in my engine. Do you think that Honda has an "equivalent" product to seafoam?
Old Jul 25, 2004 | 07:08 PM
Hawkze_2.3's Avatar
Honestly, just use the seafoam. It's very safe and will clean your engine, plus you get the pleasure of shooting smoke for 5 minutes while driving around town
Only place I know to get it is OReilly's
Old Jul 25, 2004 | 08:04 PM
Kal's Avatar
Kal
Default Re: Fuel injector cleaner good or not? (Hawkze_2.3)
fuel injector cleaner sucks, sea foam's good
Old Jul 25, 2004 | 08:33 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: Fuel injector cleaner good or not? (Kal)
i used this prolong stuff i just tried it to see if it would help when i go to the track after useing 3 times in 3 months my cat got melted now i been useing seafoam and its alot better i didnt even know about it and my store sells it
Old Jul 26, 2004 | 11:58 AM
delguiner's Avatar
Default Re: Fuel injector cleaner good or not? (raylude)
yup sea foam is the shizzznit
ef_you_again
18
Mar 25, 2005 08:25 AM
EK45VTi
10
Sep 21, 2004 07:03 PM
Platoon918
Apr 25, 2003 06:49 AM
LudemanDan
Oct 2, 2002 10:24 PM
Q-OnE
Aug 5, 2002 11:38 AM
