Is the older Profec B better than the Profec B Spec 2?
Old Jul 25, 2004 | 02:36 PM
Sprockets's Avatar
Default Is the older Profec B better than the Profec B Spec 2?
Maybe it was hooked up wrong, but a while back I tried to help a friend adjust his Spec 2 and it was a pain in the ***.
Last night I read through a shitload of posts on this forum and others. Some people love it and others hate it. Other than the need to use dip switches on the old one, it seems to cause people less problems than the Spec 2. Newer isn't always better.
I've found an older unused Spec 1 online, and was wondering if I should buy it or just get the Spec 2 and go through the usual headaches with the shitty Greddy instructions and help online. Opinions?
Old Jul 25, 2004 | 03:24 PM
95GSRTT
Guest
Posts: n/a
Default Re: Is the older Profec B better than the Profec B Spec 2? (B16A Grenade)
If you have problems working the spec 2, i dont think ANY EBC is for you. That thing is so ******* easy to install and work. Got mine all done in like 15 mins from running wires to setting it up for low and high boost.
Old Jul 25, 2004 | 06:33 PM
Sprockets's Avatar
Default Re: Is the older Profec B better than the Profec B Spec 2? (95GSRTT)
Well, then his was obviously hooked up wrong (which I had no part in). Installed and programmed in 15 minutes? No ******* way, but thanks for the input. I guess you like it.
Old Jul 25, 2004 | 06:52 PM
stealthmode62's Avatar
I've got the spec1. It's the only one I've ever had experience with. The reviews on the spec 1 said that the ***** are very sensative which I find contrary to mine. Also I still have a 1psi spike before leveling out. Still better than playing with the actuator IMO.
Old Jul 25, 2004 | 07:35 PM
u2civic1's Avatar
Default Re: (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote">I've got the spec1. It's the only one I've ever had experience with. The reviews on the spec 1 said that the ***** are very sensative which I find contrary to mine. Also I still have a 1psi spike before leveling out. Still better than playing with the actuator IMO. </TD></TR></TABLE>
i kno when vtec kicks in i also get 1 psi spike until it levels out
Old Jul 26, 2004 | 09:14 AM
Sprockets's Avatar
Default Re: (u2civic1)
Thanks, I might as well get the new one. I had no idea that the spec 1 spiked.
Old Jul 26, 2004 | 09:22 AM
PM-Performance's Avatar
Default Re: (B16A Grenade)
The new one is a PITA
Old Jul 26, 2004 | 10:07 AM
B18C1CYA's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">The new one is a PITA</TD></TR></TABLE> you can say that again, but once you get it set up its ok, but if i had to get a new one i would get something else.
Old Jul 26, 2004 | 10:24 AM
Sprockets's Avatar
Default Re: (B18C1CYA)
What would you get for around $300? I don't think there is anything.
Old Jul 26, 2004 | 10:31 AM
95GSRTT
Guest
Posts: n/a
how the **** is it a pita. Wiring it is easy as hell, and getting the settings is a turn of the **** and pushing a button? I dont see how you guys are having issues with the spec 2. never had one issue and adjusting it is as hell. Maybe im just a mother ******* genius or something Id looking into the Apexi vacr or whatever its called again. its got gear boost control, which is nice for higher hp cars
Old Jul 26, 2004 | 10:33 AM
Default Re: (95GSRTT)
its just a pain in the *** to get the settings right to hold boost solid. the instructions are wack. they call functions diff than on the boostcontroller. you must be a genious because ive talked to some of the smartest racers and tuners out there and they cant even figure the thing out.
Old Jul 26, 2004 | 10:57 AM
rioninja's Avatar
Lol, then they shouldnt be racing.
I have a original profec b (which i havnt used yet, since my car isnt 100% finished)
and my buddy has a spec 2. My friend was able to figure it out in about 15 minutes
of driving around. The spec 2 is not hard to use. I guess some people just aren't
electronically inclined
Old Jul 26, 2004 | 11:04 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">how the **** is it a pita. </TD></TR></TABLE>
PITA= Pain In The ***
Old Jul 26, 2004 | 11:11 AM
Default Re: Is the older Profec B better than the Profec B Spec 2? (rioninja)
like i said, look at the instructions then go thru the funtions and tell me it makes sense. it doesnt. the settings arent named the same 1st off. its jsut *** backwards.
blakacintegra
May 6, 2007 09:03 AM
s4yama
Apr 18, 2006 08:54 AM
civicsi940
Apr 15, 2005 03:38 PM
Ch3mik
Apr 8, 2005 05:47 AM
PM-Performance
May 20, 2003 05:19 AM
