Jun III's
Old Nov 26, 2001 | 04:03 PM
typerhatch's Avatar
New User
Default Jun III's
Will it be safe to run porflow springs and retainers with these cams? Thanks
Old Nov 26, 2001 | 04:23 PM
SBR*EG4's Avatar
Default Re: Jun III's (typerhatch)
i've heard from a few trustworthy people that the portflow setup is good enough for it but havent had any personal experience.if you dont already own them go with j.g. or any number of others which are proven. the prices on these items arent drastically different.
Old Nov 26, 2001 | 05:55 PM
kitkatR's Avatar
get the jun springs and the porflow retainers
Old Nov 26, 2001 | 07:38 PM
naturalvx's Avatar
Portflows work fine, just ask mike K. If you have portflows stick with them, if you have money and the head is off just go ahead and get the Juns. The portflows do work though.
Old Nov 26, 2001 | 08:15 PM
Mike K's Avatar
Default Re: Jun III's (naturalvx)
check the spring pressure and coil bind of the jun springs vs. the itr outer/portflow inner combo... then you'll see why i laugh at people who waste their money on jun valvetrain.
Old Nov 26, 2001 | 08:39 PM
koy's Avatar
koy
New User
Default Re: Jun III's (Mike K)
oops...
[Modified by koy, 12:52 AM 11/27/2001]
Old Nov 26, 2001 | 09:56 PM
FAST94GSR's Avatar
New User
Default Re: Jun III's (koy)
duh reread mike k's post he just told ya...
Old Nov 26, 2001 | 10:00 PM
hondura's Avatar
How much lift can the ITR outer spring before it binds?
How much for the ITR inner spring before it binds?
How much for the portflow spring before it binds?
Old Nov 26, 2001 | 10:09 PM
infinkc's Avatar
Default Re: Jun III's (hondura)
http://www.importreview.com/reviews/valvesprings.html
Old Nov 26, 2001 | 10:14 PM
hondura's Avatar
Default Re: Jun III's (infinkc)
Is that test done with just the inner springs? I dont think portflow has outer and inner springs?
But according to the chart ITR springs coil bind at 12mm, Geez doesnt the JUN cams have 12mm lift or am I missing something?
Old Nov 27, 2001 | 05:40 AM
Mike K's Avatar
portflow/ITR does NOT coil bind with the JUN3 cams. checked that already.
Old Nov 27, 2001 | 08:01 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
i ran portflow inner/ITR yellow outter with crower ti retainers with jun 3's before. 9300 rpm. no problemo. currently using the same setup with skunk2 cams to 9500 rpm.
[Modified by frank@b16a.com, 9:01 AM 11/27/2001]
Old Nov 27, 2001 | 01:24 PM
typerhatch's Avatar
New User
Default Re: Jun III's (frank@b16a.com)
which cams did you like better the new skunks or the jun III's
Old Nov 27, 2001 | 02:00 PM
buzzman's Avatar
Frank,
yeah, I also wanna know which cams you prefer. I also have the Skunk2 cams, but i still have the stock springs and retainers with stock redline.
-Buzz
Old Nov 27, 2001 | 08:22 PM
hondura's Avatar
So is the limiting factor of the coil bind the ITR inner springs? Or will they not bind either??
If there are a couple of guys running the JUN cams with those springs that means:
1. JUN is not 12mm lift OR
2. The specs on that website is wrong
I am thinking that it might be no. 2.
Oh, What outer spring are you using on the exhaust side?
[Modified by hondura, 9:23 PM 11/27/2001]
Old Nov 28, 2001 | 12:03 AM
Banned
the test was done by Tom at Portflow so you can be sure Tom did it carefully.
ITR springs would be the yellow outter and yellow inner
Portflow would be the yellow ITR outter and portflow inner
as the chart says the Portflow/ITR combo provides plenty of stiffness and coilbind safety. you can use any cam up to 12.5 mm lift no problem.
Old Nov 28, 2001 | 12:09 AM
Banned
Default Re: Jun III's (buzzman)
i had jun 3's in the car for a day on the dyno only... so i can't comment on the street performance. it was only marginally better than the CTR cams i had peak #'s wise. CTR was 175 whp and 117 ft-lbs, JUN3 was 178 whp and 118 ft-lbs. how ever the JUN3 did beat the CTR considerably after 8500. since the engine is basically stock other than valve train one can make argument with the long duration of JUN3 it would've worked well with a high CR engine. who knows. from the graph the jun3 worked great although its non-vtec performance was pretty weak compared to CTR's. however i did not tune the gears because it already has such long duartion. i wasn't sure what the adjustment window is... maybe it could've gained the low end back some. it was about 5 ft-lbs less than CTR below vtec.
i have NOT dyno the skunk2 cams in my car, they do feel awesome and pulls to 9500 rpm. people are confusing the graph i posted. it is my motor with jun3 cams vs. a totally seperate world challenge built b16a with skunk2 cams.
HKSone
10
Mar 1, 2005 03:47 AM
advanracing62
Oct 4, 2003 10:19 PM
ScottFern
May 5, 2003 08:27 AM
ScottFern
May 4, 2003 07:41 AM
AllMotorITR
Mar 8, 2002 06:13 AM
