need to know what kind of lube goes in the lude
Old Jul 25, 2004 | 11:31 AM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default need to know what kind of lube goes in the lude
i dont know what kind of gear lube goes in my 2000 5speed tranny and what kind goes in the differental i also have queaf lsd in it and im planing on useing redline or royal purple thanks for your help
Old Jul 25, 2004 | 12:30 PM
Kal's Avatar
Kal
Default Re: need to know what kind of lube goes in the lude (raylude)
use Honda MTF.
Old Jul 25, 2004 | 12:43 PM
thehondaguru's Avatar
Default Re: need to know what kind of lube goes in the lude (Kal)
redline or royal purple works
Old Jul 25, 2004 | 03:11 PM
Twiggz's Avatar
Default Re: need to know what kind of lube goes in the lude (95 lude)
I've heard good things about royal pruple but havn't tried it yet.
but when I used Redline, I found that it was great at first, but shifting started to get tough after a few k miles. had to change it more often to keep her shifting smooth. just my $.02
Old Jul 25, 2004 | 04:23 PM
raylude's Avatar
Default Re: need to know what kind of lube goes in the lude (Twiggz)
well i was wondering if there was a sertain weight or something or do i just ask for royal purple gear lube and do i use the same lube in the differential?
Old Jul 25, 2004 | 04:24 PM
Toretto's Avatar
When I had my clutched and flywheel changed out, they used Redline MTF, and it was ok at first, but 3k miles later, it sucked. I use GM synchromesh MTF, but if you havent had any grinding problems, use Honda MTF.
Old Jul 25, 2004 | 04:30 PM
raylude's Avatar
Default Re: need to know what kind of lube goes in the lude (Toretto)
ok but wat do i put in the diff?
PrOjEcT_LuDe
Dec 27, 2007 10:05 PM
gooberwolf
Dec 3, 2003 11:50 PM
slowacura
Aug 19, 2002 09:36 AM
Pure R Racer
Nov 22, 2001 06:50 PM
