gsr owners... need your help
Old Jul 25, 2004 | 10:54 AM
mingbling's Avatar
Default gsr owners... need your help
i have a civic with a gsr engine and transmission with 195/55/15 size tires. To all those that has a integra gsr/civic hatch with gsr motor swap and the same size tires. Can you please tell me the EXACT rpm at certain speeds and at what gear?
Example.. how fast is the car going EXACTLY at 2000 rpms in 2nd gear, 3rd gear, 4th gear... or maybe 3000 rpms in 2nd gear....etc.
I just replaced my speedo with a new motor because my previous one was jumpin up n down. Now that i fixed it, the hardest thing is to set my needle to the right speed. I know 80mph on 5th gear is 4000 rpms, but i have LS 5th gear though, so... dont give me rpm ranges in 5th gear. Thanks.
Old Jul 25, 2004 | 12:33 PM
conesmasher's Avatar
Default Re: gsr owners... need your help (mingbling)
Well from a GSR owner, but not in a hatch........4th gear at 4000rpm = 80mph..........and it follows suit close by througout 4th........ie, 4th gear 5000rpm =100mph 6000rpm =120mph etc.
Old Jul 25, 2004 | 01:22 PM
Smeeg Heed's Avatar
Default Re: gsr owners... need your help (conesmasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conesmasher &raquo;</TD></TR><TR><TD CLASS="quote">Well from a GSR owner, but not in a hatch........4th gear at 4000rpm = 80mph..........and it follows suit close by througout 4th........ie, 4th gear 5000rpm =100mph 6000rpm =120mph etc.</TD></TR></TABLE>
I think you mean 5th gear.
195/55/15 is stock GS-R tire size as well.
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
select the 94-01 GS-R from the drop down menu and push update. It should give you all speeds and RPMS.
You can also put those GS-R gear ratios into this one and get some nice graphs:
http://reverendsgarage.net/ind...r.php
Old Jul 25, 2004 | 03:05 PM
mingbling's Avatar
Default Re: gsr owners... need your help (Smeeg Heed)
anybody know my tire diameter in inches?
Old Jul 25, 2004 | 04:47 PM
mingbling's Avatar
23.44 inches is 195/55/15. Thanks guys
DC2Mex
Sep 18, 2018 08:17 PM
BlueTeg
Transmission & Drivetrain
Jul 28, 2014 07:57 PM
bboylito
Jun 4, 2006 02:18 PM
quik1
Apr 20, 2005 08:42 PM
