what ignition? turbo gsr ~400whp.. msd or stay stock?
Old Jul 25, 2004 | 10:44 AM
dunkd's Avatar
Default what ignition? turbo gsr ~400whp.. msd or stay stock?
right now im still breaking in my motor but I was wondering when I turn up the boost and get my hondata retuned should I upgrade to a MSD ignition? I plan on making close to 400whp...
will the stock ignition hold up or should I upgrade? If i do go with msd which do u recommend for a street driven car? MSD 6a? any input is appreciated, thanks!
Old Jul 25, 2004 | 11:32 AM
Trak_Day's Avatar
New User
Stay stock. there are tons of cars running aropund over 400whp with stock ignition. Honda ignition systems are great!
Old Jul 25, 2004 | 11:33 AM
GEN2TEG's Avatar
I ran stock ignition until I turned up the boost and am also making over 400whp. It started to misfire at high boost. I chose to go with stock Honda wires with the MSD SCI ignition box, cap and external coil. Fixed the misfire issue with no problems.
I would upgrade IMO.
Old Jul 25, 2004 | 11:39 AM
Trak_Day's Avatar
New User
Default Re: (GEN2TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEN2TEG &raquo;</TD></TR><TR><TD CLASS="quote">I ran stock ignition until I turned up the boost and am also making over 400whp. It started to misfire at high boost. I chose to go with stock Honda wires with the MSD SCI ignition box, cap and external coil. Fixed the misfire issue with no problems.
I would upgrade IMO.</TD></TR></TABLE>
Did you have all new ignition wires and whatnot when you were having the misfiring issues? Just curious because my understanding is that 400whp is fine with hondas ignition
Old Jul 25, 2004 | 06:27 PM
dunkd's Avatar
budump
Old Jul 25, 2004 | 08:13 PM
D@nnY's Avatar
I made 400 whp stock and it started brreaking up top end....msd wires and a msd coil and its good..you dont really need a Multiple spark discharge thats more for low end...the coil is what is need...HVC coil..
Old Jul 26, 2004 | 09:48 AM
dunkd's Avatar
so just wires and coil are good enough? bc that is hella cheaper than the box
Old Jul 26, 2004 | 10:24 AM
-Trinitron-'s Avatar
There are big power cars running stock ignition. Hell Erik Aguilars car runs a stock ignition. I know boost makes a difference but It is my understandng that the stock unit is sufficient.
Old Jul 26, 2004 | 10:35 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (-TRINiTRON-)
User Raped Ape made over 400+ and is on stock ignition with Hondata if im not mistaken.
Old Jul 26, 2004 | 10:46 AM
Squirtle's Avatar
Run it stock for now on low boost and save up for box and coil later.
Old Jul 26, 2004 | 11:00 AM
dunkd's Avatar
well i plan on cranking the boost and getting it retuned when im done breaking it in... i have the money to buy it, its just a matter of do i need it? like i could spend the money on getting a apexi avc-r instead of getting a MBC...
Old Jul 26, 2004 | 12:11 PM
slamedturtle's Avatar
Default Re: what ignition? turbo gsr ~400whp.. msd or stay stock? (dunkd)
i would have to stay stock unless you start having problems on the dyno then youll know if you need some other ignition mods. You have to remember if you get that **** and tune it with it you can always have problems. i would keep it as simple as possiable. none of that unnecessary bullshit. can really make it easier in the long run.
Old Jul 26, 2004 | 02:02 PM
aktuning's Avatar
Default Re: what ignition? turbo gsr ~400whp.. msd or stay stock? (slamedturtle)
hey i would upgrade if i was you because its safer for you because your going to be pushing alot of power. i have a 350hp car and i run the digital 6 and the ss coil with the stock ngk wires and my car runs great. your going to need this upgrade if u want your car to run the best it can because your going to have a lot fuel and you want to beale to burn it all up. check out summit they have the digital 6 for like 279 and the coil is like 30bucks snice u have the money i would do it
Old Jul 26, 2004 | 02:07 PM
rondigs's Avatar
Default Re: what ignition? turbo gsr ~400whp.. msd or stay stock? (aktuning)
NGK wires, MSD blaster coil, and 540hp...
Old Jul 26, 2004 | 03:20 PM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aktuning &raquo;</TD></TR><TR><TD CLASS="quote">check out summit they have the digital 6 for like 279 and the coil is like 30bucks </TD></TR></TABLE>
Summit does not have good prices on MSD products IMO
I too would upgrade if you have the $$. If you encounter any problems on the dyno or durning tuning due to ignition you wont have an msd or whatever ignition you chose with you. That means spending more $$ on more tuning. Also it is not a good idea to add the ignition after tuning due to the fact that it WILL affect your tune and would be best to be tuned with it installed.
Old Jul 27, 2004 | 07:46 PM
dunkd's Avatar
thanks for the responses
Old Jul 27, 2004 | 09:16 PM
shermanyang's Avatar
Default Re: (dunkd)
i'm gonna wait till after i hit 400whp and see if i detonate before i get MSD.
Old Jul 27, 2004 | 09:49 PM
PrecisionH23a's Avatar
B series - stock for 400
H series - MSD for anything after 350
Old Jul 28, 2004 | 12:03 AM
HYREV2NR's Avatar
What about using a SCI w/ MSD coil on a SC'd B18C5 @ 10psi? I've got the SCI sitting on the shelf that I've had for a while & not sure if I should use it or not. I figure it's worth a try.
Old Aug 7, 2004 | 09:56 PM
dunkd's Avatar
what about just getting the SS coil, cap and wires?
Old Aug 7, 2004 | 11:31 PM
Vu's Avatar
Vu
Default Re: what ignition? turbo gsr ~400whp.. msd or stay stock? (rondigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rondigs &raquo;</TD></TR><TR><TD CLASS="quote">NGK wires, MSD blaster coil, and 540hp...</TD></TR></TABLE>
How exactly do you use the coil only?
Old Aug 8, 2004 | 01:34 AM
JDM_Risa's Avatar
Default Re: what ignition? turbo gsr ~400whp.. msd or stay stock? (Vu)
this is what happens when you car misfires due to ignition issue..
this dyno is recently
i can't wait to order my
msd digital 6, ss coil blaster, msd cap, oem acura distributor rotor, ngk wires and ngk 2 step colder plugs
should solve the problem
i would recommend upgrading so when your on the dyno you don't waste dyno time and can't crank the boost up due to this problem.....i guess its really the abbuse u put ti through how much wear and tear is on your ignition system....nad how you maintain it guess you can stay stock if its permits.
Old Aug 8, 2004 | 03:16 AM
BoostedSiRhc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vu &raquo;</TD></TR><TR><TD CLASS="quote">
How exactly do you use the coil only?</TD></TR></TABLE>
yup, how do u do this?
Old Aug 8, 2004 | 05:49 AM
SuperTeg95's Avatar
Default Re: what ignition? turbo gsr ~400whp.. msd or stay stock? (BoostedSiRhc)
buy a msd cap and coil. Take yours out of your distributer and wire her up. Easy as pie.
Old Aug 8, 2004 | 05:53 AM
Default Re: what ignition? turbo gsr ~400whp.. msd or stay stock? (SuperTeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">buy a msd cap and coil. Take yours out of your distributer and wire her up. Easy as pie. </TD></TR></TABLE>
so, its just the positive and negative? is there any wire/s goin back to the distributor? thanks man
