Troubleshooting burning oil...
Old Nov 26, 2001 | 02:42 PM
jond's Avatar
Default Troubleshooting burning oil...
When a car burns oil, is there a way to tell whether its the valve seals, or the rings, or something else thats causing the problem?
Old Nov 26, 2001 | 02:43 PM
MackSpeed-616's Avatar
Default Re: Troubleshooting burning oil... (jond)
leakdown test
also, does it burn all the time or just when you really get on it?
[Modified by TurboR616, 3:44 PM 11/26/2001]
Old Nov 26, 2001 | 02:47 PM
jond's Avatar
Default Re: Troubleshooting burning oil... (TurboR616)
leakdown test
So if it only burns when you dog it, its the valves because of the increase in oil pressure?
Old Nov 27, 2001 | 05:05 AM
Hooch'n's Avatar
Most cars will burn a little oil if you get on it. Example: If you run a track event, you should/could burn a little oil and be ok. That's why you over fill when you are at the track. If you are burning a lot I would have it checked.
Old Nov 27, 2001 | 05:11 AM
jond's Avatar
Default Re: Troubleshooting burning oil... (8400-RPM)
So you use the leakdown test to determin which cylinder(s) is the culprit?
Old Nov 27, 2001 | 04:12 PM
albert butterbikini's Avatar
New User
Do you have an oil catch can? The oil could be going straight into your intake manifold.
Old Nov 27, 2001 | 04:15 PM
TodaSi's Avatar
Default Re: Troubleshooting burning oil... (typeR158)
Catch can will help, especially if you track or autocross your ITR.
Old Nov 27, 2001 | 04:54 PM
98R-1144's Avatar
Default Re: Troubleshooting burning oil... (TodaSi)
how do you know if you're burning oil?
Old Nov 27, 2001 | 05:00 PM
Luke's Avatar
Default Re: Troubleshooting burning oil... (98R-1144)
Serious?
Old Nov 27, 2001 | 05:09 PM
B2FiNiTY's Avatar
If your serious then, you can tell if you check your oil and you lose alot of it.
Old Nov 27, 2001 | 05:31 PM
98R-1144's Avatar
Default Re: Troubleshooting burning oil... (B2FiNiTY)
yeah that's what i figured. i never heard of anyone "burning oil"... i figured it was just eating up a lot of it. i was thinking that it would be something more drastic.
Old Nov 27, 2001 | 08:17 PM
Luke's Avatar
It is drastic if you are burning alot.
GO-FIGHT-KILL
Mar 25, 2008 09:23 PM
TomTomTuning
Honda S2000
32
Jul 5, 2006 06:16 AM
yojimboRSX
Jul 12, 2005 12:59 PM
TaboR
Jul 30, 2002 10:26 AM
Sam
Dec 20, 2001 10:05 AM
