What kinda oil for JRSC?
Old Jul 24, 2004 | 09:51 PM
HYREV2NR's Avatar
Default What kinda oil for JRSC?
Anyone know if the oil in a JRSC can be replaced with something equivalent?
Old Jul 24, 2004 | 10:24 PM
morepoop4u's Avatar
Default Re: What kinda oil for JRSC? (HYREV2NR)
gm supercharger oil. just go to the dealer its like 7 bux per bottle.
Old Jul 25, 2004 | 08:47 AM
prestonpark's Avatar
Default Re: What kinda oil for JRSC? (morepoop4u)
hpw do u put it in
Old Jul 25, 2004 | 10:43 AM
The-LS's Avatar
Default Re: What kinda oil for JRSC? (civic2003)
I think for most Honda setups the charge must be removed to refill. There is a hex refill nut you just add the oil until it reaches the bottom of the threads. But since the SC is mounted side ways (atleast in my B18C setup), it will act like a drain if you open it. So most likely it has to be removed.
Old Jul 25, 2004 | 05:21 PM
Default Re: What kinda oil for JRSC? (Black-LS)
do u have a ppic of the drain plug
Old Jul 25, 2004 | 07:24 PM
mrbsponge's Avatar
the oil that is used in Moss motors AKA jackson racing blowers is actually a Castor Bean Oil, it is a naturally assited product, i would reccomend prdering a service kit from them, otherwise they can never warranty it, or anyone you sell it to
Old Jul 25, 2004 | 09:31 PM
The-LS's Avatar
you would be looking for a screw that looks SIMILIAR to this. The oil can be picked up locally from a Ford or GM dealer since a lot of their cars use the same SC's.
Old Jul 25, 2004 | 09:33 PM
so drain the oil and put it in the same spot
Old Jul 25, 2004 | 11:54 PM
HYREV2NR's Avatar
Thanks for the info!
Old Jul 26, 2004 | 12:35 AM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2003 &raquo;</TD></TR><TR><TD CLASS="quote">so drain the oil and put it in the same spot</TD></TR></TABLE>
thats how I know it as. You can call Magnuson or JR/Moss and ask. But I had a Ford 3.8L V6 SC which used the Eaton M90 SC which is the same design as most of the Honda units. And thats how we changed our SC Fluid. Except the way our SC was mounted we can check and add fluid to the SC with the blower still in the car because the SC was mounted upright. So we'd use a turkey baster to extract the old fluid out the fill hole and then add fresh fluid. Technically, the fluid from what I've heard doesn't really need to changed or what not. If fluid is missing or whatever... you probably got other problems elsewhere.
Old Jul 26, 2004 | 09:19 PM
my jrsc is knocking im not losing any boost is my jrsc geting messed up
Old Jul 26, 2004 | 11:16 PM
HYREV2NR's Avatar
MMMM....not sure. One way to check is to loosen the SC belt & move it back & fourth to see if theres any free play in the pulley. It shouldn't be. If it is, youve got problems.
Old Jul 27, 2004 | 11:24 AM
nope there no free play on the pulley
Old Aug 3, 2004 | 02:38 PM
icivicracer's Avatar
hey i have a jrsc on my ls in my eg.. and i hydrolocked the engine..has any 1 had this happen? what happens 2 the sc.. it spins fine and there is no play.. jackson says look 4 chiped teflon.. if its chiped will it be bad 2 put on my b20??
Old Aug 3, 2004 | 02:52 PM
Red_Greddy_Si's Avatar
Default Re: What kinda oil for JRSC? (icivicracer)
the actual oil is caster bean oil. if you can find it thats what JR will sell you.
en00be
Feb 19, 2009 08:26 AM
LitlGuy
Nov 8, 2007 09:06 PM
Andre
Nov 10, 2003 04:05 PM
