Dyno #'s inside
Old Jul 24, 2004 | 09:11 PM
ViperRedCRX's Avatar
Default Dyno #'s inside
this is on pump gas tuned pretty safe at 18psi, also not reving it out all the way yet.
here is the setup:
https://honda-tech.com/zerothread?id=922394
Old Jul 24, 2004 | 09:15 PM
z6's Avatar
z6
y not use more psi? ur motor is pretty built...
Old Jul 24, 2004 | 09:17 PM
SpdFrk's Avatar
Default Re: Dyno #'s inside (ViperRedCRX)
Nice numbers.
Whats are u using for managment? Also hows the idle on those precision 1000cc?
Modified by SpdFrk at 1:30 AM 7/25/2004
ArinX's Avatar
nice numbers
Old Jul 24, 2004 | 09:24 PM
Default Re: Dyno #'s inside (ArinX)
hondata s200 is the managemant. fuel system is just a walboro 255hp and 6an from the pump banjo up.
1000's idle pretty good
Old Jul 24, 2004 | 09:25 PM
Casey's Avatar
good **** basically same setup i have, and ill have numbers in a month or so
Default Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">y not use more psi? ur motor is pretty built...</TD></TR></TABLE>
i will when i do my race gas tune
Old Jul 25, 2004 | 01:07 AM
shermanyang's Avatar
Default Re: (ViperRedCRX)
do you idle rich with those 1000cc injectors? i know i had to retard my timing a bit and richen up my idle a bit with my 1008cc injectors.
Old Jul 25, 2004 | 01:36 AM
Default Re: (shermanyang)
it idles pretty nice. in the high 13-low 14 af range
Old Jul 25, 2004 | 06:10 AM
Sinitron's Avatar
That's neat, we almost put down identical numbers, at the same PSI.
Only difference is my compression ratio, and smaller turbo.
Old Jul 25, 2004 | 07:49 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: (Sinitron)
nice #'s
good luck with your 500hp goal' keep us updated.
Old Jul 25, 2004 | 10:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinitron &raquo;</TD></TR><TR><TD CLASS="quote">That's neat, we almost put down identical numbers, at the same PSI.
well i was wanting to run lower boost for pump, but the 44mm wg i ordered got back ordered, so i just ordered a 38 for the moment, and it can't keep up. i had to pull some timing up top to bring the power level down.
Old Jul 25, 2004 | 10:29 AM
Chillin94hatch's Avatar
Old Jul 26, 2004 | 05:36 AM
Default Re: (Chillin94hatch)
thanks for the props guys. have been waiting quite a while to drive this thing.
Arturbo
Nov 1, 2005 10:47 PM
VTECJUN
64
Oct 28, 2005 10:58 PM
b00stedbyFastrax
Jun 20, 2005 02:17 PM
Pfieff
Nov 10, 2003 01:38 AM
ActiveAero
May 8, 2003 10:22 AM
